SolaraGuy.com • View topic - WHOA
WHOA
WHOA
Postby HwEaNnRgY » Fri Jul 09, 2004 3:03 pm
so i was really lazy and decided to go to a touchfree carwash and before i knew i had some issues with my door. Anyways so as the car is being washed i see some water inside my car and later i figure that it was coming from the windows. ANYWAYS i think my doors alignment is off wack because i have to slam the drivers door for it to close. SO does toyota warranty that stuff or am i assed out?
HwEaNnRgY
Postby michaels artic frost » Fri Jul 09, 2004 3:59 pm
HHHHMMMMMMMMM....that's a good question, have you called your local Toyota?
Updated 06/01/12: Michael T's
Postby Keg-Of-Iron » Fri Jul 09, 2004 5:25 pm
well, it all depends on whether you are still within the warranty. I work at toyota headquearters in the CR dept., and I beleive that is under comprehensive(3 months or 36k miles). For proper diagnosis take it to the dealer and let them see whats wrong, then depending on your service history, accidents and warr they will make a decision. If you absolutely think you did nothing wrong and your car was made that way from the factory, call the CR dept and see what we can do for you.
FIGHT ON U.S.C.!!!
2000 SE v6 5spd Supercharged! 6 lb. pulley...
http://www.cardomain.com/memberpage/510493
Keg-Of-Iron
Postby Parke10 » Fri Jul 09, 2004 11:04 pm
i have the same prob with drivers door its messed up and now from closing is startin 2 mess up the molding and ive taken it in 2 toyota 3 times they said it was fine and ment 2 do that for air,the damn thing sounds like it gonna shatter when i close the door
Parke10
Postby HwEaNnRgY » Mon Jul 12, 2004 4:31 pm
YEA IT DOES SOUND LIEK THE GLASS IS GONNA SHATTER. x-__-; anyone know about any recalls or anything about that though?
HwEaNnRgY
Postby Parke10 » Mon Jul 12, 2004 8:22 pm
i called again i was told it is outta aline caused by closing the door hard by the glass not the door only person i think mighta done that is the tint place
Parke10
Postby RichP » Wed Jul 21, 2004 8:23 am
i think im getting the same problem. i get a wet drivers side back floor after i wash the car.
Does anyone know how to adjust the window?
RichP
