SolaraGuy.com • View topic - Rotors...
Rotors...
Rotors...
Postby dabigswoll » Sun Jul 11, 2004 1:05 am
How much would it cost to replace front and rear rotors along with pads....Also, which brands should I get? Labor wouldnt be a problem because from previous posts, ya'll make it sound like its not that bad, so i can prolly do it.
dabigswoll
Postby that1mexguy » Sun Jul 11, 2004 7:10 am
if you do a search, you'll find that most people will recommend you to do it yourself. I myself have posted some instructions on how to do ALL that, but when i did an estimate on my car for all 4 wheels, it came to over $300.... that's when i decided to do it myself.
that1mexguy
Postby whiteflash » Sun Jul 11, 2004 9:00 am
it came to a total of 235 for me
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby michaels artic frost » Sun Jul 11, 2004 9:34 am
If it's your first time, do one side at a time to have something to reference it to, in order to put it back the correct way. I have not changed rotors for my 04 Solara yet. However, I've changed it on my camry and mx-3. The first time took about 1:30 minutes. Thereafter, was much easier.
GL
Updated 06/01/12: Michael T's
Postby dabigswoll » Sun Jul 11, 2004 10:24 am
do yall know of any cheap places that sell power slot rotors and hawk brake pads for cheap? I think this is a pretty good set-up right? Or should i try something else...
dabigswoll
Postby Grazi07 » Sun Jul 11, 2004 10:48 am
again the search function...... try ebay, I know you can get rotors there, prolly the pads to... I got Metalmasters off ebay for a decent price
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby Mole » Sun Jul 11, 2004 3:16 pm
why do most people stop at rotors and brake pads?
dont forget to buy steel braided brake lines!!!!!
Postby pythonjosh » Sun Jul 11, 2004 3:31 pm
I'm guessing here, but do steel braided brake lines increase pressure in the brake lines by being less flexible when applying the brakes?
pythonjosh
Postby Mole » Sun Jul 11, 2004 7:03 pm
not necc increase pressure, but doesn't flex comparing to stock brake lines.
in the process after upgrading, you get a better response brake feel, which i know feels a lot better and more secure.
Postby bassthrive » Sun Jul 11, 2004 8:54 pm
Do the steel brake lines make your brakes operate as if they were all or nothing? My friend replaced his lines with steel on his car and he said you gotta be real careful with the pressure you apply. A little dosent fully apply the brakes, but if you push too hard your head is through the windshield it stops so fast.
So what Im asking is, do you lose the linear feel the stock brakes have?
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Sun Jul 11, 2004 9:53 pm
what car does your friend have?
that does not sound correct. (all or none braking.)
perhaps he just stomped on the brakes too hard that time.
with our cars having the upgrade, gives the braking a little better response and a firmer brake once more foot pressure is engaged.
Postby Yanks0114 » Mon Jul 12, 2004 9:39 am
For more info on SSBL just do a quick search, but as TRDmole said they increase response and give a firmer pedal feel.
Under high pressure, rubber brake lines expand a little resulting in a loss of braking power. SSBL do not expand nearly as much therefore you get instant pedal response and a firmer brake. However, it does not decrease the smooth brake feel of the solara
Postby pythonjosh » Mon Jul 12, 2004 11:25 am
Okay back to the topic. Here's all the rotors and brake pads under 'Solara' on ebay:
Ebay search results for Solara Brakes
Not too pricey if you ask me.[/url]
pythonjosh
Postby SolaraT » Mon Jul 12, 2004 5:53 pm
O yeah and watch out for so called "Brembo Cross Drilled and Slotted" Rotors. Brembo does not make those. Brembo only makes them either Cross Drilled or Slotted. Not both. An aftermarket company modifies the rotor and resells them under the Brembo name. This comes from Brembo themselves.
Here is there 2004 catalogue... See page 57-58 for the part numbers available for Toyota Camry and Solara
http://www.brembo.com/NR/rdonlyres/88D2 ... talog2.pdf
Right click and save as.
Acrobat Reader .pdf file.
SolaraT
Solaraguy need mo power guy
