SolaraGuy.com • View topic - Auto downshift braking
Postby HydroponiK » Fri Jul 16, 2004 7:49 am
I frequently turn off overdrive (shift to 3rd) on my auto to help assist with braking when I'm trying to slow down fast. Do you guys think it's safe for the tranny?
HydroponiK
Postby Mole » Fri Jul 16, 2004 8:05 am
it's safe on the trans, but by doing so, you are wearing the trans down faster.
only do so if you are in need of a FAST stop.
brakes are cheaper than trannys.
Postby HydroponiK » Fri Jul 16, 2004 8:07 am
That makes sense, thanks for the quik relpy. :)
HydroponiK
Postby Jai_Jai_Binks » Fri Jul 16, 2004 8:42 am
the only time i disengage od is when i need more rpm's to take off...n i have to agree the dude above...brakes are cheaper than a new tranny (thats one of the reasons i never down shifted on my m/t ie. engine braking..i usually dropped it in neutral and coasted till stop lights).
Postby hari-bhari » Fri Jul 16, 2004 10:30 am
if you ever are in a situation where you need to slow down real fast, punching your brakes and having the ABS kick in will provide enough stopping power to negate any small difference that downshifting creates. it will put strain on your tranny, and like jai said, replacing brakes is cheaper than replacing a tranny. in short, i wouldnt do it...
hari-bhari
Postby somethingcool » Sat Jul 17, 2004 1:14 am
I think the only time it would be appropriate to turn off the o/d like that is on a long descent that you might have to worry about the brakes overheating. Basically you want to turn off the o/d in hilly terrain and leave it on for the flat stuff.
somethingcool
