SolaraGuy.com • View topic - Noise SHock????
Noise SHock????
Noise SHock????
Postby 99SEAUTO » Fri Jul 16, 2004 9:11 am
Everytime i hit a bump, leave the driveway the right rear side makes a noise like blup, i dont now if thats a common problem do the shocks go easily on solaras or anyone had this problem????
99SEAUTO
Postby s e y t o n » Fri Jul 16, 2004 10:03 am
i have a similar problem, but only when i take turns aggresively with someone sitting in the rear right seat. this is probably because i have TRD springs on stock shocks. what is your suspension set up?
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Postby WortownSolara » Fri Jul 16, 2004 12:10 pm
its actually a pretty common problem with our platform, im 90% sure that its the strut MOUNT. i had the same issue, and my toyota tech swapped em out for me, and presto chango everything is smooth again
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
Postby Jai_Jai_Binks » Fri Jul 16, 2004 12:50 pm
WortownSolara wrote:its actually a pretty common problem with our platform, im 90% sure that its the strut MOUNT.
I think that prob is more common on the gen 4 camry's than on gen 1 solara. Also, it could be berings that have gone bad??? What your milage....
Postby 99SEAUTO » Fri Jul 16, 2004 5:01 pm
i got almost 73k, im leaning towards the shock, but then again i dont now im gona have to put it on a lift take it apart
99SEAUTO
