SolaraGuy.com • View topic - clutch
clutch
clutch
Postby eugene5786 » Sat Jul 17, 2004 7:26 am
okay driving yesterday, when i pushed on gas a little, no grip. explanation, dead clutch no grip. So now i gotta get a new clutch. im gonna get the fionza flywheel to go with it, and proberbly gonna get the trd clutch from toyotapartsstore.com. but im thinking maybe a clutchmaster instead. you guys got any input? by the way i work on my car so i need something that will last.
eugene5786
Postby Keg-Of-Iron » Sat Jul 17, 2004 11:45 am
Hey man, I have been thinking about getting a clutchmaster, possibly stage 3
FIGHT ON U.S.C.!!!
2000 SE v6 5spd Supercharged! 6 lb. pulley...
http://www.cardomain.com/memberpage/510493
Keg-Of-Iron
Postby cdssolara » Sun Jul 18, 2004 12:51 am
I've had a Clutchmasters Stage 2 and a Fidanza flywheel for about 2 years, and I'm very happy with the combination. The clutch is just as easy to engage as stock, and has better holding power. The flywheel requires some additional rpm for engagement, especially on hills, but otherwise is very smooth. I had been worried about slightly rough idling before buying it, but that hasn't been a problem, at all.
cdssolara
Postby eugene5786 » Sun Jul 18, 2004 11:01 am
cdssolara Posted: Sat Jul 17, 2004 11:51 pm Post subject:
hmm, how much did it cost you? mine is complety dead, when i put it into gear the car does not even stall. i cant have the car down for to long. maybe i should just go to the dealership and get an oem.
eugene5786
Postby cdssolara » Mon Jul 19, 2004 1:05 am
The clutch was around $450 and the flywheel was just under $400, if I remember correctly. I think they can be had for less now, though. The installation was just over $1000, but it also included installing a limited slip differential.
cdssolara
