SolaraGuy.com • View topic - rear brakes?
rear brakes?
rear brakes?
Postby supamouse09 » Mon Jul 19, 2004 10:11 pm
i know this has probably already been asked and answered but i couldn't find it in the search. the rear brakes on a 2001 sle are drum or are they disc??
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby geminimouse » Mon Jul 19, 2004 10:15 pm
disc/drum
unless they changed it in 01...
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby whiteflash » Mon Jul 19, 2004 10:34 pm
i got a 2001 and mines disc
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby AzN_DrAgoN48 » Mon Jul 19, 2004 10:44 pm
doesn't it depend on the engine. i'm pretty sure the v6 has discs all around and the i4 has discs in front and drums in the back for all trims
2001 Dark Blue Solara SE V6
8000k Osram HID
Silverstars fogs
Clear Corners
Passport 8500 Hardwired
Two Alpine 12" Type R Subs
JBL BP600.1
AzN_DrAgoN48
Postby Rudy » Mon Jul 19, 2004 10:58 pm
edmunds.com is your friend.
all 2k1 v6 solaras had discs
99 Solara V6 5SPD
Rudy
Postby Mole » Mon Jul 19, 2004 11:08 pm
a simple glance is all you need.
if the rear look anything close to the front, then you have disc brakes.
if the front and rear look totally different, then your rear has drum brakes.
Postby TheTamago » Mon Jul 19, 2004 11:22 pm
I'm still a newbie at mechanical things and I wanna learn. Did a search on what Drum breaks are, but couldn't find anything solid. Since i;m on a I4 2000 Solara with the front rotor/rear drum setup. Can you give me a good technical explaination on how drum breaks work?
And a related question. In the future. Can the break system be changed to all rotor type breaks?
TheTamago
Postby bassthrive » Mon Jul 19, 2004 11:28 pm
http://auto.howstuffworks.com/drum-brake.htm
this website is your friend :D
and to answer your second question, yes I beleive you can convert to discs all around.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby supamouse09 » Mon Jul 19, 2004 11:45 pm
thanks alot for the answers guys. i may have been working on my car for a while, but i am still a newb :D
supamouse09
Postby geminimouse » Tue Jul 20, 2004 5:46 am
AzN_DrAgoN48 wrote:doesn't it depend on the engine. i'm pretty sure the v6 has discs all around and the i4 has discs in front and drums in the back for all trims
Then the V6 has discs in the front and rear has disc and drum.
Don't go messing with the rear brakes thinking it's just discs.
08 Accord Coupe
geminimouse
Postby bronzemaxell » Tue Jul 20, 2004 6:19 am
i think you are correct
according to the manual book for solara, the v6 has front disc and rear disc, it also has drum in disc on rear for parking brake.
bronzemaxell
Postby TadS » Tue Jul 20, 2004 8:29 am
TheTamago wrote: Can you give me a good technical explaination on how drum breaks work?
1. They don't :P. No really there are two shoes inside the drum that press outward against it creating some drag. The are very ineffective vs. disc.
2. Yes, but it requires a lot more than just the rotors. There is a DIY posted on doing the conversion.
TadS
Postby Jai_Jai_Binks » Tue Jul 20, 2004 3:43 pm
also to add: not all 4 bangers came with disc/drum combo. The ABS versions came with all 4 disc's. :wink:
Postby Jon11582 » Tue Jul 20, 2004 3:46 pm
Jai wrote:also to add: not all 4 bangers came with disc/drum combo. The ABS versions came with all 4 disc's. :wink:
Not mine. Mines discs in front and drum in back, but I got ABS.
2000 Black Solara SE
Jon11582
