SolaraGuy.com • View topic - Sttering wheel shakes when i brake....
Postby oompah2788 » Thu Jul 22, 2004 5:57 am
I think i remember someone having this same problem and i THINK i read this on this forum so i tried searching but i got nothing...posts that didnt have to do anything with shake or brakes..... but anyways......... my problem is.. everytime i brake with moderate pressure above 20-30 mph, the steering wheel shakes or vibrates... and it shakes more faster,stronger, the more faster i brake from or the harder i press the pedal..... i just got new tires and had my wheels aligned so im pretty sure thats not the problem... what do you think here?? maybe i have warped rotors?? help me out.. THANKS!!!!!!!!!!!!!!!!
oompah2788
Re: Sttering wheel shakes when i brake....
Postby offthahook » Thu Jul 22, 2004 6:39 am
oompah2788 wrote:I think i remember someone having this same problem and i THINK i read this on this forum so i tried searching but i got nothing...posts that didnt have to do anything with shake or brakes..... but anyways......... my problem is.. everytime i brake with moderate pressure above 20-30 mph, the steering wheel shakes or vibrates... and it shakes more faster,stronger, the more faster i brake from or the harder i press the pedal..... i just got new tires and had my wheels aligned so im pretty sure thats not the problem... what do you think here?? maybe i have warped rotors?? help me out.. THANKS!!!!!!!!!!!!!!!!
Rotors may need turned or wheels may need balanced. Start there; I bet it's one of those things.
offthahook
Postby SolaraT » Thu Jul 22, 2004 6:46 am
Rotors - Resurface needed
Brakes - Probably worn also
Go to Just-Brakes and have the 4-wheel friction reline for only $99.99
http://www.justbrakes.com/reline.htm
Hope you are around one...
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby prowlerartist » Thu Jul 22, 2004 9:09 am
yeah its the rotors, i had the same problem. Got it fixed and now a smoothe ride again
prowlerartist
Postby groovespacer » Thu Jul 22, 2004 9:46 am
Betting on resurfacing rotors. Are the OEM or Drill or slot?
groovespacer
Postby SC V6 » Thu Jul 22, 2004 10:07 am
mine do that... how much does a shop charge for re-surfacing?
SC V6
Postby onefiend » Thu Jul 22, 2004 10:14 am
Is there any specific time or mileage to bleed the brakes? I'm over 60k miles and havent bled the brakes yet. Thanks
onefiend
Postby groovespacer » Thu Jul 22, 2004 11:18 am
Should be 30- 40.(that range is cool)
groovespacer
Postby oompah2788 » Thu Jul 22, 2004 4:36 pm
i have oem brakes..... yah i had thought that it was the rotors.....i guess ima have to resurface them and get new pads.... The just-brakes deal sounds real good but unfortuneatly im in hawaii and theres none down here.... yes, how much does it cost usually to have your rotors resurfaced and how much does oem brake pads cost....and this is for both front and rear.... Would it be cheaper to take off the rotors myself and bring it down to the shop or would it be the same just to have them take it off there??? Thanks!
oompah2788
Postby indiglosolara » Thu Jul 22, 2004 4:41 pm
if your going to resurafce your rotors you might as well get new ones. Its not that much more.
Just a though.
I just got new brembo slotted rotors and axxis Ultimate brake pads... for 140.00... for the front.. and the install is pretty easy.. im having a shop install them for me and the cost is only $25.00...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby oompah2788 » Thu Jul 22, 2004 7:48 pm
do you think its only the front brakes that are causing the shake or would the rear cause it too??? (doubt it cause the front are connected to the steering).... but would i need to change or resurface the rear anyhow??? i would get new rotors depending on how much resurfacing costs..... do yo uknow how much resurfacing runs around?? if i get new rotors and pads i could install them myself...... Thanks
oompah2788
Postby oompah2788 » Thu Jul 22, 2004 7:50 pm
oh, and where did you buy the rotors and pads??? do they have solid rotors? not slotted or drilled, cause i dont want to attract any thieves or anything........... thanks! :D
oompah2788
Postby groovespacer » Thu Jul 22, 2004 10:10 pm
groovespacer
Postby oompah2788 » Fri Jul 23, 2004 3:50 am
should i do the rears too??? and the $140 for rotors and pads.... were those for fronts only........ and how much do pads run and do i get them at a toyota dealer or something??? Thanks! :D
oompah2788
Postby indiglosolara » Fri Jul 23, 2004 12:38 pm
oompah2788 wrote:should i do the rears too??? and the $140 for rotors and pads.... were those for fronts only........ and how much do pads run and do i get them at a toyota dealer or something??? Thanks! :D
my were only the front.
the axxis pads and rotors i got a hook up on..
$140 was for everything in the front..
indiglosolara
Solara 2 xB
Solara 2 xB
