SolaraGuy.com • View topic - 2000 Se V6 Solara Fog Light
Postby Dawgz » Fri Jul 23, 2004 8:42 pm
I had a 94 camry LE that used 9006 Bulbs, i baught xenon bulbs for the car and took them out when i traded the car in, i know the fog lights for the solara use 9006 also, i wanted to know if 12v 80W ones are safe for the fog light..if not then does anyone know wat wattage is good?
Postby WTF?? » Fri Jul 23, 2004 8:54 pm
i THINK its supposed to be at 55W or 60W to be safe... then again im not at home to let you know. sorry man
anyone else wanna confirm?
Retired... its been fun Image
WTF??
Postby whiteflash » Fri Jul 23, 2004 11:08 pm
im pretty sure its 55w
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby Yanks0114 » Fri Jul 23, 2004 11:53 pm
i think its 55w also.
The 80w ones are a joke and a risk because they could burn your wiring harness and light housing
Postby Jai_Jai_Binks » Mon Jul 26, 2004 8:38 am
i know from personal exp (in my celica) using higer Wattage bulbs in your fogs leads to premature burns..and constant replacement. (i think a fella solaraguy dude) was also having this problem a month back. Since i changed to 55W bulbs...no premature burns in the bulbs....Yeah, they light up more...but they wear off more often as well. if you have something already, surely you can use it..but be ready to replace it in 3 months.
Postby WortownSolara » Mon Jul 26, 2004 10:16 am
its is VERY bad for your electrical system to run a higher wattage bulb.
If it doesn't kill you.....it only makes you faster!
WortownSolara
Audio Guru
Audio Guru
