SolaraGuy.com • View topic - What kind of tire pressure do you guys run?
Postby stosh » Tue Aug 03, 2004 6:51 am
I'm running a stock tire setup on a 2001 and was curious what all you guys run.
I know I could read in the book but I know people often run less than what the users's manual says.
stosh
Postby MalBandito99 » Tue Aug 03, 2004 7:10 am
32 psi all around like it says on the sticker inside the door.
MalBandito99
Postby Jai_Jai_Binks » Tue Aug 03, 2004 8:19 am
Winters is 32 for me, summers i keep it around 30 - but then again i have that 2 dollar tire pressure pen, i'm sure its accurate, but not THAT accurate!
Postby ICrazyChrisI » Tue Aug 03, 2004 8:33 am
Whenever I get my oil changes done, they always stick my 225/45/17s w/ 40psi..isn't that too much?
ICrazyChrisI
Postby Mole » Tue Aug 03, 2004 9:07 am
it depends on what tire you have.
some max psi go from 36psi all the way to 51psi.
in the summer, keep it lower as heat makes air expand.
in the winter, keep it higher as cold makes air more compressed.
Postby stosh » Tue Aug 03, 2004 9:29 am
Wow, thanks guys!!
Ok I'll go with what's on the door.
thanks for the help!
stosh
Postby Mole » Tue Aug 03, 2004 10:39 am
do not go with what is on your door if you have replaced the tires before.
Postby stosh » Tue Aug 03, 2004 11:58 am
TRDMole177 wrote:do not go with what is on your door if you have replaced the tires before.
Tires and rims or just tires?
stosh
Postby PureNocence » Tue Aug 03, 2004 12:46 pm
I go with around 40psi on my NITTOS, the max is 50 and I have this peev about feeling like my tires are flat :P
PureNocence
Postby stosh » Tue Aug 03, 2004 12:55 pm
PureNocence wrote:I go with around 40psi on my NITTOS, the max is 50 and I have this peev about feeling like my tires are flat :P
Wow, thats crazy!
Thats more then I run in my mtn bike. :)
stosh
Postby SolaraT » Tue Aug 03, 2004 4:49 pm
35 RL---\--- 40 FL
40 RR---/--- 35 FR
Only because of one tire that is very hard to balance and I have to keep it on the rear right to avoid shakes in the front.
Max 40 psi / Yokahoma AVS es100 / 235/40/18
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby PureNocence » Wed Aug 04, 2004 12:09 pm
stosh wrote:Wow, thats crazy!
Not really...I find I get better gas mileage too.
PureNocence
Postby stosh » Wed Aug 04, 2004 12:23 pm
Oh heck yeah it made a heck of a difference in my Xterra running an extra 5lbs in the summer when I'm only doing highway driving.
stosh
Postby impactX » Sat Aug 07, 2004 1:47 am
The rule of thumb is for every inch increase in wheels diameter, add 2-3PSI to the stock pressure and don't exceed the maximum pressure shown on the tire.
impactX
