SolaraGuy.com • View topic - trim on panel and doors.
Postby xsolara33x » Thu Aug 05, 2004 10:12 am
hey guys, i was wondering if anyone knows how to take off the trims on the front panels and on the doors... im thinkin about doing something to them... thanks in advance... i thought i read somewhere how to take them off, but i cant find that thread anymore... thanks again...
xsolara33x
Postby Hsakuragi » Thu Aug 05, 2004 10:58 am
professionally, u suppose to take out the whole door panel in order to get the trim off.
Some of us just pop it out with a screwdriver and use glue gun to glue it back
Hsakuragi
Postby xsolara33x » Thu Aug 05, 2004 11:00 am
so how would you take it off when you remove the whole panel? would it be the same thing to just popping it off with a screwdriver? what kind of glue do you use? thanks in advance...
xsolara33x
Postby geminimouse » Thu Aug 05, 2004 1:22 pm
Just pull them off carefully. It's held in by clips.
Glue is not necessary.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby krook » Tue Aug 10, 2004 12:58 pm
i think the whole deal with taking the door off is so that you can see how the trim is held in. but i'm pretty sure they should just pop right in. i'd take the door off anyway, just to be safe. it's about 3 bolts and 2 screws holding the door panel to the door.
krook
Postby xsolara33x » Tue Aug 10, 2004 2:01 pm
all i had to do was pop the trim off... i put some carbon fiber vinyl on them... does anybody know how to have the vinyl mold on to the item itself? i had some wrinkles on the corners and round areas, just wanted to know so I could do it over again perfectly... thanks in advance...
xsolara33x
Postby geminimouse » Wed Aug 11, 2004 4:01 pm
xsolara33x wrote:i had some wrinkles on the corners and round areas, just wanted to know so I could do it over again perfectly... thanks in advance...
Wrinkles are from excess vinyl...u'll need to cut it perfectly for the corners and round areas for no wrinkles.
08 Accord Coupe
geminimouse
Postby krook » Wed Aug 11, 2004 8:51 pm
what is this vinyl that you speak of? and where does one purchase this miraculous product of fancy-ness?
krook
