SolaraGuy.com • View topic - low oil level on dipstick? 99 se/v6
Postby donna » Thu Aug 12, 2004 7:22 pm
oil level was on the lower hole on dipstick, but i got the 4.7 quarts out when i changed the oil,,,,are the dipsticks unreliable, and how low on oil till the idiot light comes on, wish these came with the oil pressure gauge standard.
donna
Re: low oil level on dipstick? 99 se/v6
Postby bronzemaxell » Thu Aug 12, 2004 8:01 pm
donna wrote:oil level was on the lower hole on dipstick, but i got the 4.7 quarts out when i changed the oil,,,,are the dipsticks unreliable, and how low on oil till the idiot light comes on, wish these came with the oil pressure gauge standard.
i think as long as the oil level is not below the lower hole, you should be fine. is the car on level ground when you look at the dipstick?
i normally buy 5 quarts, and fill up the oil filter first, then put the rest in the engine, after a little dripped out of the oil filter while putting it back on, the dipstick reading is in the middle.
bronzemaxell
Postby Jai_Jai_Binks » Fri Aug 13, 2004 10:15 am
when are you reading your dipstick! is the engine a little warmed up?
Postby donna » Fri Aug 13, 2004 5:03 pm
checked it cold this morning after an oil change and still below bottom hole on dipstick, w/5 qts....i will just have to keep an eye on it, how much extra oil can be added without damage to engine?
donna
Postby geminimouse » Fri Aug 13, 2004 5:38 pm
lower than the bottom hole? Do u see any leaks?
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby donna » Fri Aug 13, 2004 6:52 pm
no leaks, just not sure about at least adding a little just to see it on the stick,,,maybe my stick is not stock , it has a yellow circle pull, sound right?
donna
Postby Hsakuragi » Fri Aug 13, 2004 10:30 pm
that is OEM
Hsakuragi
Postby Yanks0114 » Sat Aug 14, 2004 12:29 pm
What kinda filter are you using?
Also, do you know about how much oil drained out when you changed the oil. That sounds very odd. Even a leak would require the oil to heat up before you'd have a problem, unless its a giant hole.
Something doesn't sound right here
Postby Jai_Jai_Binks » Mon Aug 16, 2004 9:31 am
excess oil does produce white smoke..does your car puff out white smoke?
