SolaraGuy.com • View topic - Water in fog lamps
Water in fog lamps
Water in fog lamps
Postby mox » Sun Aug 15, 2004 12:49 am
I see many 1st gen Solara with water in one of the both fog lamps.
Is this a common problems for these cars ?
I recently got a Solara and there was some rust on the driver side fog.. And every times it rains a lot or I get the car washed, I see that there is some water inside..
The lens is not broken and the housing seems to be fine.
How can I remove the fog lamp assembly so I can get a closer look and fix it if it can be fixed ?
Thanks
--Ben
'99 Red Solara SE V6, 5 speeds
Previous cars:
'99 Corolla, 5 speeds ('99-'01)
'97 Camry XLE V6, AT ('01-'02)
'92 Camry SE V6, 5 speeds ('02-'04)
mox
Postby Jackass-Jeff » Sun Aug 15, 2004 9:36 am
it happened to my gen 1.5, but they replaced it when I was under warranty =\
1GR-FE ftw!
Jackass-Jeff
Postby bassthrive » Sun Aug 15, 2004 10:02 am
One of my fogs would fill with water after the rain so I took it out one day to get a closer look. (access it from under your car, you'll have to undo part of the splash guard) The lamp housing was cracked so I cleaned the water and resulting algae out of the fog, let it dry, and sealed the crack with silicone. No water or condensation since.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby mox » Sun Aug 15, 2004 10:08 am
bassthrive wrote:One of my fogs would fill with water after the rain so I took it out one day to get a closer look. (access it from under your car, you'll have to undo part of the splash guard) The lamp housing was cracked so I cleaned the water and resulting algae out of the fog, let it dry, and sealed the crack with silicone. No water or condensation since.
- Paul
Exactly what I need to do ;)
I already removed the splash guard from under the fog lamp but how do you remove it from the bumper ?
I see a bolt when I put my head under but it looks like an adjustement bolt so I don't want to touch it...
--Ben
Previous cars:
mox
Postby bassthrive » Sun Aug 15, 2004 12:14 pm
I did not completely remove the splash guard, I just undid a few of the bolts and pushed it out of the way so that I could unscrew the fog light. Lemme know if you are still stuck.
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
