SolaraGuy.com • View topic - Bad day...
Bad day...
Bad day...
Postby krazeee1707 » Sun Aug 15, 2004 6:39 pm
Well..woke up this morning and started my car...when I got back, I shut the car off and hear a strange noise. I popped the hood and it turns out my pcp valve was loose and disconnected. I have no idea how long it has been like that. The car does run fine though. Then by noon I decide to do and oil change. I ended up stripping the oil pan. I've done hundreds of oil changes and have never done that before :( . First question, what damages can occur w/ my pcp valve out like that? Second, besides buying a new oil pan...anyone else know what I can do stop my oil from leaking out of the plug. The plug will not tighten anymore. :roll:
krazeee1707
Postby Mole » Sun Aug 15, 2004 7:31 pm
for the oil, buy a new plug.
Postby bassthrive » Sun Aug 15, 2004 7:31 pm
I wouldnt worry about the PCV. The problems with the PCV start when it is dirty and closed up. For the oil drain plug I have no idea dude. Maybe coat the threads with a little bit of silicone?
- Paul
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Sun Aug 15, 2004 7:40 pm
i dont know about silicone. what would happen if it mixes with the engine oil?
that wouldnt sound too good.
just call a friend or last resort bus/taxi to autozone or something.
Postby Dawgz » Sun Aug 15, 2004 7:42 pm
hmm
get a bigger sized nut so itll be a tight fit?
Postby Dawgz » Sun Aug 15, 2004 7:43 pm
i have a threader kit, to drill holes then make threads in them, woot for ebayyyyy
Postby krazeee1707 » Sun Aug 15, 2004 7:46 pm
TRDMole177 wrote:for the oil, buy a new plug.
I wish it was just that easy...the oil pan is stripped..the bolt is fine.
Dawgz, how much did you get that threader kit for?
krazeee1707
Postby Dawgz » Sun Aug 15, 2004 7:48 pm
i dont remember i think 50-70
cause it came with tools to do holes, and to do the screw itself.
Postby Mole » Sun Aug 15, 2004 8:05 pm
if you are going to re-thread the oil pan, i recommend you to take the oil pan out.
if you dont, metal shavings will be left inside the oil pan and can lead to bigger problems.
Postby Stock Solara SEV6 » Mon Aug 16, 2004 7:57 am
I would think you could get by without pulling the pan. Once you have it re-tapped, and the bolt installed, fill the crank case back up with oil and drain it again (without running the motor). That should flush most everything out.
2001 V6 5-speed
Stock Solara SEV6
