Engine idle speed V6 2000 Solara with SC
- Paladin06Greg
- Torqued Solara
xRAVExBoIx wrote:Remember, your tach is analog and your S-AFC is digital. The digital one is probably the correct one since it's a # , not just an arrow. =P
Auto Idles (working temperature) around 750-850.
Manual idles (working temperature) around 700-750
Poman wrote:Hmm it's about time people start to notice the problem. I too have the same low idle characteristic. My SAFC read the same as the tech around 700 but dip below it to around 600-650 and the car sputters and struggles to go back to normal. My check engine light comes on every 10 miles or so for bank 1 too lean (p0171)...i have this problem for a year and a half, i keep reseting it with the OBDII scanner.....
I think it's either, 1. fuel filter, 2. MAF sensor 3. O2 sensor 4. fuel injector/rail or 5. PCV valve (which I replaced) 6. none of them...dunno.
Anyone got any idea?
