SolaraGuy.com • View topic - Missing piece
Missing piece
Missing piece
Postby S99Solara » Mon Aug 30, 2004 11:26 am
Does anyone with a Dealers manual know where does this part belongs to? I was taking my dash apart the other week and when putting back everything together i found out i have an extra piece of metal that and couldn't figure out where i got it from. pretty sure it's not from the driver side. anyway here is the picture of it
http://www.project-w.com/~sorjai/kevin/metal.jpg
S99Solara
Postby Mole » Mon Aug 30, 2004 3:05 pm
it looks like it would go on "under the dash" panel.
if you sit in the driver's side, it would go where your knee points.
Postby S99Solara » Mon Aug 30, 2004 4:13 pm
i will give it a try this weekend, thanks.
S99Solara
Postby pythonjosh » Mon Aug 30, 2004 5:46 pm
TRDMole177 wrote:it looks like it would go on "under the dash" panel.
I dunno dude. I've been under the dash many times and I can't say that I recognize this piece. But if it is under the dash somewhere, which is also what I suspect, the bolts would be a 10mm bolt if not 14mm. And if you don't see a place for it on the driver side, look behind the glove box, and if not there then look behind the center console/CD player etc.
Good luck, and I'll take a look under my dash to try to help you out in a few.
Josh
pythonjosh
Postby S99Solara » Mon Aug 30, 2004 7:29 pm
yeah this piece have two 10mm bolts
S99Solara
