SolaraGuy.com • View topic - squeaky clutch
squeaky clutch
squeaky clutch
Postby hari-bhari » Wed Sep 01, 2004 5:02 am
my clutch pedal squeaks. not only the actual pedal itself inside the car (where i can hear a little creak), but i also noticed taht when i'm inside the parking deck, i hear an actual squeak from inside the engine bay whenever i press/release the pedal. it occurs for the full length of pushing in/releasing the pedal and sort of sounds like a squeaky swingset or door might sound. is this a problem? easy fix? should i take it to the dealer for warranty work?
hari-bhari
Re: squeaky clutch
Postby DavPak » Wed Sep 01, 2004 5:31 am
hari_trivedi wrote:is this a problem? easy fix? should i take it to the dealer for warranty work?
ehh, sticky situation, since there is no warranty on a clutch.......its a wear and tear item. but the noise may be coming from something else.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Turbosolara » Wed Sep 01, 2004 7:44 am
just check your brake master cylinder if there is any leak by the firewall. newer car integrated clutch master cylinder with brake master cylinder. you should not cosume brake fluid at all
Postby Jai_Jai_Binks » Wed Sep 01, 2004 8:53 am
on my dad's cressida, the clutch used to squeek (maybe your squeek and this squeek was different). I just LAVISLY sprayed lubricant all over the clutch pedal and whatever the thin staw could go to....(not knowing if this was good or bad for the car). The squeek was gone..but it came back yearly..and did the same!
Postby toy4x4boy » Wed Sep 01, 2004 9:51 am
Easy fix, my car did the same thing. Grab a can of white lithium grease (at least that is what I used) and spray the clutch pivot points under the dash and then have someone push the pedal while you stick your head in the engine bay and locate the squeak. Spray the pivot points in the engine compartment. Squeak gone (at least for me). My shifter also squeaked when I would move it from nuetral to 1st and 2nd gears. Easy to find the pivot point by looking in the engine compartment.
toy4x4boy
Postby s e y t o n » Wed Sep 01, 2004 9:54 am
i have the same problem, my mechanic looked at it and said it was the ball bearing joint or something. he sprayed wd-40 on it (in the engine bay) and the noise isnt as loud now. but he said you have to really get in there and put some grease or lube on that joint, but its not going to hinder any performance or anything. no big deal if you can live with a lil noise.
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Postby Keg-Of-Iron » Wed Sep 01, 2004 11:30 am
Hey I am glad this issue just found a fix b/c I have had the same sqeak for a while now and haven't done much about it except for turning my radio up. Thanks alot guys!
FIGHT ON U.S.C.!!!
2000 SE v6 5spd Supercharged! 6 lb. pulley...
http://www.cardomain.com/memberpage/510493
Keg-Of-Iron
Postby hari-bhari » Wed Sep 01, 2004 2:08 pm
yea i mean its not that loud, i can only hear it in a parking deck because of the echos and what-not. but just wanted to make sure that its not a sign of a problem.
hari-bhari
Postby S99Solara » Thu Sep 02, 2004 5:07 am
I have the same problem on my car. I did spray some WD40 on and the sound was gone for a day only and came back on. pretty sure that my clutch need to replace since i already have over 90k miles already.
S99Solara
Postby Fletch » Thu Sep 02, 2004 5:13 am
I have this condition also. My local mom/pop mechanic said it is common with Toyotas and does not indicate any kind of failure mode. I does not bother me so I have not tried to correct it.
Some lubes/oils break down rubber so careful what you spray on seals.
2006 Legacy GT spec.B
Fletch
Postby that1mexguy » Thu Sep 02, 2004 6:20 am
Keg-Of-Iron wrote:Hey I am glad this issue just found a fix b/c I have had the same sqeak for a while now and haven't done much about it except for turning my radio up. Thanks alot guys!
Ditto!!! LOL thanks everyone!
:drinking:
that1mexguy
Postby TRD MCV20L » Thu Jul 21, 2005 12:26 am
Thanks!
TRD MCV20L
