SolaraGuy.com • View topic - Mobil 1?
Mobil 1?
Mobil 1?
Postby Yanks0114 » Sun Sep 29, 2002 12:39 pm
hey, what is everyones though on Mobil one oil. I love my 2001 Solara and want to do everything possible to make it last as long as possible. I currently have 22,000 miles on it and i just use regular oil. I have heard great things about mobil 1
Postby NASTY » Sun Sep 29, 2002 12:46 pm
i was just bout to ask that...or about synthetic oil in general
and would it be better to stick with toyota's synthetic?
'01 SLE V6
NASTY
Postby ericatdallas » Sun Sep 29, 2002 1:18 pm
I've asked this before.. no reply.
As long as you change your oil and oil filter every 3k miles, you should be just fine. Sythetic oil has a hire boiling point so it can resist more heat, but you're not likely to need it. Another benefit, it doesn't leave mineral deposits in your system.
But it's not likely to make much difference, but it's your money.
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
btw, I use synthetic anyway :)
ericatdallas
Postby onefiend » Sun Sep 29, 2002 1:28 pm
Toyota's genuine motor oil isnt synthetic BTW NASTY... I have 25,000 miles on my car and had just switched to Castrol Synthetic rather then using Toyota's motor oil. I went to Jiffy Lube and they suggested that Mobil 1 was decent but that most of them were using Castrol synthetic, I decided on the Castrol...maybe next time I'll try the Mobil 1.
onefiend
Postby ultramookie » Sun Sep 29, 2002 2:26 pm
Is there any benefit with using synthetic over "real" oil?
ultramookie
the guy pulling all the levers
Postby Blaze » Sun Sep 29, 2002 2:44 pm
u cant cook chicken on synthetic :P
Blaze
Postby Jay » Sun Sep 29, 2002 4:29 pm
synthetic is definitely a better quality oil.. It reduces more friction.
Because of the less friction, it's suppose to increase 0.5 HP or something....
Only thing is it's definitely more expensive... and people say once you switch to synthetic, you shouldn't go back to regular oil..
Jay
Postby NASTY » Sun Sep 29, 2002 7:44 pm
i know toyota uses regular oil, but the have a synthetic oil too if you want (at least my dealer said so)
'01 SLE V6
NASTY
Postby ultramookie » Sun Sep 29, 2002 7:45 pm
Jay wrote:synthetic is definitely a better quality oil.. It reduces more friction.
Does the system have to be "flushed" in order to put synthetics in? Or can the regular oil be drained and then synthetic be put right in?
ultramookie
Postby Blaze » Sun Sep 29, 2002 7:46 pm
id say flush it
Blaze
Postby onefiend » Sun Sep 29, 2002 8:53 pm
you say flush it, I say you can drain it and replace it with synthetic..and just use synthetic there on after. :lol:
onefiend
Postby ericatdallas » Sun Sep 29, 2002 8:59 pm
Okay, just about everything increases horse power according to the advertisers. Even platinum plugs .. PLEASE! Where's the rolling eye smilie when you need it. I'm not saying it's not possible, I'm going to need to see the hard facts before you can change my mind on this. Besides, if that's the only benefit, I don't see much point. 0.5hp isn't much, even on a lawn mower.
Synthetic oil has less mineral deposits, less carbon, a higher boiling temperature, and is not as viscous (I guess this is the less friction part?).
There are definite benefits to using synthetic but it's debateable whether or not you'll ever realize those benefits in such a short time and whether it offsets the cost.
you can drain it without flushing.
ericatdallas
Postby bassthrive » Mon Sep 30, 2002 10:05 pm
has anyone used aftermarket oil filters?
i know k&n makes a filter thats supposed to flow more and i have found it for about $10 online. im coming up to oil change time and im wondering if its a good investment over a regular old plain-jane filter you would get at jiffy lube.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby ericatdallas » Mon Sep 30, 2002 10:50 pm
bassthrive wrote:has anyone used aftermarket oil filters?
definitely buy a quality brand name filter. It does make a difference.
ericatdallas
