SolaraGuy.com • View topic - squeky noise when turning left
Postby Ryan » Thu Sep 09, 2004 7:29 am
I just felt it today on my way to school everytime i will steer left ie: turning left I will hear a squaky sound coming from the driver side of the hood suspension help???
Ryan
Squeaky noise
Postby SleeperSolara » Thu Sep 09, 2004 7:41 am
Yeah that same thing happens to my 98 Camry, it makes this clicking noise on the right front side of the car. The dealer said it was the suspension, but it wasn't. I think it is the steering mechianism.
Postby Parke10 » Thu Sep 09, 2004 9:38 am
axles, CV joints?
Parke10
Postby s e y t o n » Thu Sep 09, 2004 11:11 am
i have the same problem sometimes :x
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Re: Squeaky noise
Postby Stock Solara SEV6 » Thu Sep 09, 2004 11:23 am
SleeperSolara wrote:Yeah that same thing happens to my 98 Camry, it makes this clicking noise on the right front side of the car. The dealer said it was the suspension, but it wasn't. I think it is the steering mechianism.
I clicking during turning is a CV joint going out. Usually caused by a torn boot causing dirt and sand to get in and ruin the joint.
2001 V6 5-speed
Stock Solara SEV6
Postby Ryan » Thu Sep 09, 2004 11:40 am
okay maybe it will help out if I tell you guys that I installed tein/tokico combo 3 weeks ago but it just started squaking now help???
Ryan
Postby Stock Solara SEV6 » Thu Sep 09, 2004 1:35 pm
Did you replace the "strut mounts" or "suspension supports" when you replaced your struts? These can cause squeaking or groaning when turning at slow speed.
http://www.zer0.info/solaraguy/viewtopi ... 23&start=0
2001 V6 5-speed
Stock Solara SEV6
Postby Ryan » Thu Sep 09, 2004 3:41 pm
Stock Solara SEV6 wrote:Did you replace the "strut mounts" or "suspension supports" when you replaced your struts? These can cause squeaking or groaning when turning at slow speed.
nope but that's exactly what im having the squeaking only happens on slow speeds
Ryan
Re: Squeaky noise
Postby SleeperSolara » Fri Sep 10, 2004 6:58 am
No it isn't the CV joints, because they are still in good condition.
Postby Ryan » Fri Sep 10, 2004 9:12 am
i just had it look on a Toyota dealer and they cant find anything they said normally camry/solara has this problem when the suspension is modified
they said not to worry much its no big deal :)
Ryan
