SolaraGuy.com • View topic - 18x8 +42 offset
18x8 +42 offset
18x8 +42 offset
Postby Ford_Fixorrepairdaily » Thu Sep 09, 2004 12:23 pm
I got a really good deal on these 18x8 with +42mm offset. I have a strut and spring combo and i was wondering will my car rub?
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby xsolara33x » Thu Sep 09, 2004 12:31 pm
i have 18 x 8.5 with +42mm offset up and have spacers ... if you get some spacers you won't rub... you might want to roll your fenders... thats my next step... but have not had any problems... good luck...
xsolara33x
Postby Ford_Fixorrepairdaily » Thu Sep 09, 2004 1:03 pm
wat size are your spacers and do you have a strut and spring setup as well? thanks dude
Postby Jackass-Jeff » Thu Sep 09, 2004 1:46 pm
careful with spacers. they are dangerous. they crack over-time (pretty fast, 2 years or so).
I have a 50 offset on 18x8 and I'm fine :D
1GR-FE ftw!
Jackass-Jeff
Postby i20solara02i » Thu Sep 09, 2004 1:59 pm
your fine. you dont' need spacer or anything. if your running strut and spring.
i20solara02i
Postby indiglosolara » Thu Sep 09, 2004 5:46 pm
you should be fine...
i have 7.5 with 42 and still have some room left. Only reason im running a spacer is to push the wheels out a little more... but other then that i wouldn't run it...
indiglosolara
Solara 2 xB
Solara 2 xB
