SolaraGuy.com • View topic - 00' HP
00' HP
00' HP
Postby Craziluke » Sat Sep 11, 2004 12:40 pm
hye i own a 2000 solara thats a 4 cylinder and i really want to know how much horsepower it has under the hood and its 100% stock so please if you nkow how much it has or where i can find out how much it has please give me your help!! good deal 8) Luke :o
http://www.cardomain.com/memberpage/605241
Im out like the deaf kid in musical chairs
Craziluke
Postby TheTamago » Sat Sep 11, 2004 1:27 pm
When I last remember. The 1999-2001(2?) 5s I4 engines produce around 135HP @ 3000RPM? somewhere around there but I know i got the HP right.
The 2z or whatever that came with the 2002-2004 which is another I4 engine cranks up to about 157HP which has VVTI as well?
Go check around the forum or look in your handbook about your call. Usually those handbooks give u all the specs that u need to know about your car from Gas Tank Volume holding to location of spare wheel and other stuff.
TheTamago
Postby Dawgz » Sat Sep 11, 2004 2:15 pm
Exterior
Length: 190 in. Width: 71.1 in.
Height: 55.1 in. Wheel Base: 105.1 in.
Ground Clearance: 5.3 in. Curb Weight: 3120 lbs.
Interior
Front Head Room: 38.3 in. Front Hip Room: 53.6 in.
Front Shoulder Room: 55.3 in. Rear Head Room: 36.3 in.
Rear Shoulder Room: 52.9 in. Rear Hip Room: 49.3 in.
Front Leg Room: 43.3 in. Rear Leg Room: 35.2 in.
Luggage Capacity: 13.8 cu. ft. Maximum Seating: 5
Performance Data
Performance
Acceleration (0-60 mph): 8 sec. Braking Distance (60-0 mph): 139 ft.
Road Holding Index: .77 g Base Number of Cylinders: 4
Base Engine Size: 2.2 liters Base Engine Type: Inline 4
Horsepower: 136 hp Max Horsepower: 5200 rpm
Torque: 150 ft-lbs. Max Torque: 4400 rpm
Maximum Towing Capacity: 2000 lbs. Drive Type: FWD
Turning Circle: 38.1 ft.
Fuel Data
Fuel
Fuel Tank Capacity: 18.5 gal.
EPA Mileage Estimates: (City/Highway)
Manual: 23 mpg / 32 mpg Automatic: : 23 mpg / 30 mpg
Range in Miles: (City/Highway)
Automatic: 425.5 mi. / 555 mi. Manual: 425.5 mi. / 592 mi.
