SolaraGuy.com • View topic - help, my starter is not working properly...common problem???
Postby LatinUSMC » Mon Sep 13, 2004 10:07 pm
about a month ago i noticed that when i would turn the ignition key the starter would hesitate to respond for a split second but did just fine ...but a few days ago it stated not responding for a few seconds...i went to auto zone and the clerck said he has a solara same year(o1 se 4cyl and has never had problem)plus the starter will run $175.00 that other than the fact that im fixing the body from previous accident
anyone have similar problem?
LatinUSMC
Postby geminimouse » Tue Sep 14, 2004 6:08 am
i had this problem...it would hesitate for about a month then it just wouldn't start the car. It was an easy replacement.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby pythonjosh » Tue Sep 14, 2004 10:39 am
A friend of mine with the solara 1mz had to replace the starter. I have never had a problem, but it's not hard to replace. Possibly the easiest engine component to replace. Just $$$
pythonjosh
Postby s e y t o n » Tue Sep 14, 2004 5:08 pm
i had a similar problem. the 5s-fe engine has a common problem with the idle control valve. this sometimes causes the car not to start, especially if its dirty. it costs around 250 to replace it, sometimes you can get it cleaned and it will work fine. id say to get that checked first before buying a starter.
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Postby sunrise_solara » Fri Sep 17, 2004 7:04 pm
^I think LatinUSMC means that the starter is not engaging the flywheel. Sometimes it will click, other times it will just spin. The brushes might be worn out. Toyota tends to have trouble with the starter, because I just replaced one on my 85 R22 4x2. It is easy to do, and see if you can get one at a boneyard.
sunrise_solara
