SolaraGuy.com • View topic - What does Frontsway bar do??
Postby impactX » Mon Sep 30, 2002 10:44 pm
I know that the rear swaybar can neturalize understeering and reduce body roll, however, what does the front swaybar do? does it neturalize understeering? or produce understeering?
impactX
Re: What does Frontsway bar do??
Postby Flipside909 » Tue Oct 01, 2002 7:28 am
impactX wrote:I know that the rear swaybar can neturalize understeering and reduce body roll, however, what does the front swaybar do? does it neturalize understeering? or produce understeering?
With a FSB, you get a little understeer and in some occassions, oversteer. Most people don't know how to control the new dynamics of a car with their FSB and RSB combo. Unless you plan to do alot auto crossing or something, I wouldn't recommend the FSB for a regular daily driver. It also harshens up your ride and puts more vibration into your steering.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby cdssolara » Fri Oct 04, 2002 4:02 pm
I agree with Flipside regarding the understeer and potential for oversteer. Controlling the car with stiffer front and rear bars may require using the throttle to induce oversteer now. The stiffer front bar does make the ride a bit harsher, but it's not all that noticeable if you have already upgraded your suspension with lowering springs and complementing struts.
I disagree about the steering, though. I find that the steering is tighter and much more responsive, with no added vibration. I think it makes a big improvement to the steering, which is a bit numb in stock mode.
Overall, the addition of stiffer front and rear bars has made the car feel very stable. There is now almost no body lean, at all. On big sweeping curves, the car now hugs the road like a sports car. I will be very careful about pushing the car too hard on quick turns and S curves until I get a complete feel for what it will do with it's new handling dynamics, however.
cdssolara
