SolaraGuy.com • View topic - RX300 block
RX300 block
RX300 block
Postby PASolara » Mon Sep 20, 2004 6:25 am
Hello i am in the prosses of rebuilding a Solara motor. So i was doing some research and noticed that the rx300 has the same 3.0 as us but the Comp ratio is 10.5:1 when ours is like 9.2:1 or something like that. So what i was woundering is if i could just bolt the heads from a camry on there and since it has higher compression and it would give me more power.
sorry if this seems to be a dumb qestion but i have to know :drinking:
PASolara
Postby SC V6 » Mon Sep 20, 2004 6:35 am
I'm not 100% positive, but almost, im sure the heads won't mate up to the block the correct way... and it probably wouldn't seal up.. causeing more and more problems... if I were you I would just modify the heads of the camry... to have higher compression... I wouldn't mix and match, cause most likly it won't match up correctly
SC V6
Postby PASolara » Mon Sep 20, 2004 6:50 am
Oh ok thanks for your help
PASolara
Postby krawzyazn » Mon Sep 20, 2004 11:20 am
you can try it if you want and let us know
its like a LS vtec
you know what i mean you never know till you try and look how good the LS vtec's are
