SolaraGuy.com • View topic - the problem with having an aftermarket exhaust...
Postby krook » Fri Sep 24, 2004 8:42 pm
is that you'll never when the sumnumbnumbbitch is gonna fall right the hell off! i had a JIC 505SUS bullet exhaust and it never really did anything odd. . .till last night. as i was leaving 24hr fitness, the damned thing just fell off at midpipe! after a long night of workin' out i was NOT in the mood for wrenching.
so now i fixed the problem, but i was wondering if it will fall off again. i tightened it as much as i could, but because it hangs so low, i fear it may happen again. what's the best solution to ensure it won't fall off?
krook
Postby Mole » Fri Sep 24, 2004 8:59 pm
there's no way it can just fall off like that. if it's true, then i find that REAL hard to believe.
were the bolts still there when you had a look under?
loosen the bolts, adjust how you want it, hold that position by having a friend of use a jack stand and re-tighten.
Postby SolaraT » Sat Sep 25, 2004 7:07 am
Yeah crazy ish man. Just falling off like that. :o
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby TRD_solaRa » Sat Sep 25, 2004 5:37 pm
that is shytty deals man!
TRD_solaRa
Re: the problem with having an aftermarket exhaust...
Postby PureNocence » Mon Sep 27, 2004 11:19 am
krooked Solara wrote:is that you'll never when the sumnumbnumbbitch is gonna fall right the hell off! i had a JIC 505SUS bullet exhaust and it never really did anything odd. . .till last night. as i was leaving 24hr fitness, the damned thing just fell off at midpipe! after a long night of workin' out i was NOT in the mood for wrenching.
Is your exhaust having performance anxiety?? :o :D
PureNocence
Postby toy4x4boy » Mon Sep 27, 2004 2:10 pm
My exhaust is fully welded so it won't be fallin off anytime soon (unless a weld happens to break which seems highly unlikely).
toy4x4boy
Postby kondo » Mon Sep 27, 2004 4:09 pm
Thats sucks krook you should complain to the manufacturer or something. Did you put it on youreself the first time?
kondo
SolaraGuy StickerGuy
Postby krook » Tue Sep 28, 2004 11:55 am
Mole wrote:there's no way it can just fall off like that. if it's true, then i find that REAL hard to believe.
yep, the bolts were still there. i tightened that badboy when i installed it with my breakerbar and made sure that stuff wouldn't come off. someone suggested that maybe someone tried to steal the exhaust but i doubt it; i parked between 2 cars.
PureNocence wrote:Is your exhaust having performance anxiety?? :o :D
hey baby, this little mishap aint no reflection of the owner now... :wink: :lol:
krook
