SolaraGuy.com • View topic - Both reverse lights stopped working
Postby nkx1 » Sun Oct 03, 2004 2:43 pm
Anyone know what could cause this?
I checked the bulbs (bought new ones, still don't work) and I checked the fuse. I'm scared this might be really expensive to fix for something as lame as reverse lights. :(
Any suggestions are much appreciated!
2001 SLE, Diamond White Pearl
nkx1
Postby Duffman » Mon Oct 04, 2004 6:02 am
I'm not a mechanic, but if it's not bad bulbs or a bad fuse then whatever sensor or switch tells the car that the tranny is in reverse is likely the culprit. Probably a computer module... and probably not cheap :(
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby s15lara » Mon Oct 04, 2004 10:57 am
mine does the same thing but mine went out little by little. i am still having this problem and still have no reverse lights. with my lights, they would not go on sometimes but if i would jiggle the wires a certain way they would come back on. i think that i might have a water leak from the trunk (like if it rains or wash the car). could it be that? cuz now they just dont come back on. help any1?
s15lara
Postby 749009 » Mon Oct 04, 2004 12:30 pm
one thing you could try as far as diagnosis goes, it to have someone stand behind the car while you very slowly move the gearshift from Park to Drive.
I've seen it happen where the indicator sensor on the gearshift itself has shifted and the reverse lights still come on at some other point in the gearshift lever's travel, but, not when the gearshift is placed in reverse.
749009
Postby s15lara » Tue Oct 05, 2004 10:05 pm
but i have a 5spd. i dont know what to try, any ideas any1?
s15lara
Postby Mole » Tue Oct 05, 2004 10:41 pm
dig up the wire under all the carpet and see if there is an exposed area.
since its not at the bulb side, then you must trace to the other side.
you might want to reserve a weekend for this task.
Postby SC V6 » Wed Oct 06, 2004 6:00 am
the plug for the sensor is on the tranny.. it has 2 wires going to it.. check and make sure its still plugged into the tranny... check fuses... if nothing else pull the reverse sensor out of the tranny and test it
SC V6
Postby nkx1 » Wed Oct 06, 2004 9:29 pm
Thanks for the replies guys. I think most of your responses related to the auto though. I actually have a stick. Any other suggestions?
nkx1
