SolaraGuy.com • View topic - LEAKING COOLANT!!!
LEAKING COOLANT!!!
LEAKING COOLANT!!!
Postby importtuner2oo4 » Sun Oct 03, 2004 6:24 pm
hey guys,
curious to know if anyone has any suggestions as to what this problem could be. I took my car out today for the first time since Sept 24th. There was a puddle of coolant under my car which i didnt notice till i got back home. I opened the hoood and saw smoke coming out of my timing belt. I think it might be my water pump, but im not quite sure.
Any suggestions would be greatly appreciated.
Thanks
Rajat
importtuner2oo4
Postby Hsakuragi » Sun Oct 03, 2004 7:34 pm
check ur hoses, ur radiator to see signs of cracking
Hsakuragi
Re: LEAKING COOLANT!!!
Postby indiglosolara » Sun Oct 03, 2004 7:41 pm
importtuner2oo4 wrote:hey guys,
Thanks
Rajat
for what your saying it sounds like your water pump is leaking. I wuld get that changes asap before it seizes up and mees up your timing.
also the upper radiator house runs by that spot check that before you do what i mentioned above.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby onefiend » Sun Oct 03, 2004 11:07 pm
how many miles on your car? do what the people above said, check hoses, water pump..etc
onefiend
Leakin' coolant
Postby SleeperSolara » Mon Oct 04, 2004 7:10 am
It might be the front drain plug.
Check that.
Cause i just flushed my system and put in a new thermostat, and had tigthened the front drain plug, and i keep leakin' out the coolant. Until i tightened really hard, until it can't go anymore[try not to strip it]
Also check the water pump housing.
Postby importtuner2oo4 » Tue Oct 05, 2004 1:43 pm
thanks for the replies. I took it to my mechanic today and we figured it out. The water pump was leaking, so i replaced that and since i was in that area did a new timing belt too.
Thanks again
Rajat
importtuner2oo4
