SolaraGuy.com • View topic - Key ring light turns on and off while driving.
Postby SolaraGuy22 » Mon Oct 18, 2004 8:08 pm
I noticed this morning while driving to work that the light by my key kept coming on and then turning off and wondered if this is an electrical problem or what? Has anyone had this happen or know what this is? Thanks for your help
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby pythonjosh » Mon Oct 18, 2004 9:50 pm
Does your door open light on the cluster come on at the same time? If so it has to do with a door sensor. Is the key ring light the only thing that turns on?
pythonjosh
Key rings light
Postby SolaraGuy22 » Mon Oct 18, 2004 9:54 pm
I actually have my dome set to off so I wouldn't know if it was switching on as well. I will switch it to turn on when the door is opened and see if it does it. I didn't even think about the door sensor. I will let you know later on if it happens again today.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
