SolaraGuy.com • View topic - gas mileage & throttle response
Postby Masshole » Thu Oct 21, 2004 7:47 am
As the weather is getting colder I've noticed my gas mileage has taken a dive(350/tank with 70% highway on 87) and my power in general seems to be down (seat of the pants feeling) especially on 87. I do not have any check engine lights - this is a 99 auto 3.0 with 102k miles - plugs & wires (denso ik22 ngk blues) fuel filter, K&N all new with regular oil changes. Are there any sensors that might be malfunctioning enough to throw things off but not cause a CEL? I especially think the cold weather is having an effect so perhaps there's an air charge sensor or something that could be out of whack?
Any suggestions are greatly appreciated.
99 Solara SE w/ tokicos and eibachs - fun around corners
86 Mustang GT (lots of goodies) - fun in straight lines(SOLD)
Masshole
Postby bassthrive » Thu Oct 21, 2004 8:18 am
Your engine should make more power with the colder air. Maybe your stations already made the switch to winter gas? I dunno....
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Masshole » Thu Oct 21, 2004 8:22 am
I know cold air is denser and should make more power which is why I'm baffled.... never heard about "winter gas".
Masshole
Postby bassthrive » Thu Oct 21, 2004 8:28 am
Hey this may seem like a "duhhh-yeah" suggestion but check your tire pressure. The cold weather may cause your tires to be a few psi low, which will effect your gas mileage and performance.
:drinking: :drinking: :drinking: :drinking: :drinking: :drinking:
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SC V6 » Thu Oct 21, 2004 10:39 am
ecu could also be adjusting
SC V6
Postby Mole » Thu Oct 21, 2004 12:06 pm
possible injectors are clogged.
it might just be your head.
Postby Masshole » Thu Oct 21, 2004 12:08 pm
I'll check the tire pressure. ECU adjusting for waht? a colder temperature? I would think that would be automatic pretty much.
Injectors clogged... wouldn't that throw a code?
You're right it could be my head - but I filled up with 87 and did normal driving (70% highway I'd say) and got ~350 miles on the tank - that's just barely over 20 which seems pretty crappy to me... don't you think?
Masshole
Postby Mandarinsolara » Thu Oct 21, 2004 5:35 pm
is altitude a factor? dads old mustang loved the air in californias mountains 10 times more than here in jacksonville
Mandarinsolara
Postby Fletch » Fri Oct 22, 2004 5:47 am
Around my area, they switched to winter gas at the beginning of December. I don't think it will make a difference in performance/economy though.
2006 Legacy GT spec.B
Fletch
Postby DatSRBoi » Fri Oct 22, 2004 7:27 am
Maybe the car is getting old? Or maybe your driving style changed.
Postby Masshole » Fri Oct 22, 2004 8:20 am
Altitude is not a factor and my driving style has not changed.
Yes, the car is getting old which is why I was wondering if there are any sensors that may need to be replaced that are not throwing a code. On that line of thinking, are valve adjustments ever necessary on these cars when they get up there in mileage? I have changed the oil religiously so the internals should be fine.
Masshole
Postby SE4ME » Sat Oct 23, 2004 7:57 am
Could be a number of factors - such as not getting the tank as topped off as you think.....
Brake calipers dragging??
Quality of fuel.....
SE4ME
2002 SE V6 Red - of course !!
"Ruby"
SE4ME
