SolaraGuy.com • View topic - Ahh Need Specs for 02 Solara SE (4 Banger)
Can Flipside do it?
Poll ended at Fri Oct 18, 2002 1:34 pm
Yes
3
60%
No
1
20%
Maybe
1
20%
Total votes : 5
Postby Jackass-Jeff » Fri Oct 11, 2002 1:34 pm
HELP! The assignment is due on Thursday (Saturday for Richard)
Here's a challenge for FlipSize (Yea... that's it! :D )
Does anyone know any of the following:
Normal or Minimum Cranking Compression ___ PSI
Cylinder Head Bolt Torque ___ Ft/Lbs.
Valve Lash Clearance: Intake _______ Exhaust ______
The Radiator Cap Pressure
Thermostat Temperature
Type of Refrigerant used in the A/C
Spark plug Gap
Spark Plug Torque
Engine Firing Order
#1 Cylinder Location
Ignition Timing
Timing Mark Location
Engine Idle Speed @ operating temperature
(In relation to spark plugs in the distributorless system...)
Magnetic Pickup Type
Airgap Measurement
Location of Pickup
Coil Pack OR Coil-on-Plug
Fuel Pump Pressure
Caster
Camber
Toe
THANKS IN ADVANCE :lol:
1GR-FE ftw!
Jackass-Jeff
