SolaraGuy.com • View topic - @#$% up my electrical... please help
Postby pervo » Sat Oct 23, 2004 7:36 am
pics
^ here are the pics
i was refered here by a fellow sounddomain member...hopefully you guys can help
i did some wiring upgrades (big three) in my engine. (ie alt to ground, alt to poss battery, battery to ground)
obvously i was careless because..
upon turning on my car the airbag light came on...
i checked the fuses and my "100 A alt" fuse was blown
i tried to remove it and the plastic housing came out but the prongs stayed
they are in there real good, possibly soldering themselves from the heat
i tested the prongs with a volt meter and they read .05 v w/ engine on and 0 w/ engine off
if anyone could offer insight on how to remove these prongs and/or what further damage i have potentialy caused
pervo
Postby pervo » Sat Oct 23, 2004 12:38 pm
any one? :(
pervo
Postby Mole » Sat Oct 23, 2004 12:59 pm
you try using needle nose pliers?
Postby pervo » Sat Oct 23, 2004 1:31 pm
oh yes... off to get some liquid wrench... if anybody knows of an online junkyard or so let me know
i tried TAP they said they had none- it was rtight before close on friday so that may have been a factor, b/c there web sight shows a dozen solaras, not to mention the camry has the same fuse block
dealer quote is in excess of $200 just for the main fuse block
pervo
Postby Mole » Sat Oct 23, 2004 1:49 pm
vise grip needle nose?
