SolaraGuy.com • View topic - Radiator drain
Radiator drain
Radiator drain
Postby 99er » Sat Oct 12, 2002 9:00 am
Mainatainence question -
Does anyone know where the drain plug/petcock on 99
solara -V6.
I haven't found it st the corners. Do I need to take
the under side shroud off?
Just looking to drain, flush, refill.
Thanks
99er
99er
Postby ericatdallas » Sat Oct 12, 2002 10:06 am
According to the Haynes guide there are two drain plugs on the engine block. Hard to describe since the neither the picture or the instructions are very detailed.
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
Postby Luc » Sun Oct 13, 2002 8:01 am
Yes, you will need to take the front lower metal "splash" guard off with a 10mm socket. Once off, you will see ONE draincock exposed from the radiator. Typically, you probably don't need to drain the coolant from the engine block, but here is what the left (front) one looks like.
I couldn't find the right (rear) one since there wasn't enough room in there to roam around.
Luc
1998 S/C'd 1MZ-FE A/T
Luc
Re: Radiator drain
Postby Flipside909 » Mon Oct 14, 2002 1:08 pm
99er wrote:Mainatainence question -
solara -V6.
Thanks
99er
You will have to remove the splashguard to get better access to it.
Try to use the Toyota Red Antifreeze/Coolant if you can.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Users browsing this forum: Google [Bot] and 15 guests
