SolaraGuy.com • View topic - PO 135 and how to fix it
Postby all_red » Thu Nov 11, 2004 12:12 pm
I was driving down the highway this morning and the check engine came on. I went to autozone and its PO135 which is the O2 sensor.
I want to know what could be wrong and how to fix it. I think there might be different things to it other than replacing the sensor.
Thanks,
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby DatSRBoi » Thu Nov 11, 2004 1:00 pm
Do you know what exactly is wrong with the O2 sensor?
Postby Mole » Thu Nov 11, 2004 1:04 pm
*2
P0135
(DI–240)
Heated Oxygen Sensor Heater
Circuit Malfunction
(Bank 1 Sensor 1)
Open or short in heater circuit of heated oxygen sensor
Heated oxygen sensor heater
ECM
Postby SleeperSolara » Thu Nov 11, 2004 1:39 pm
Open up both O2 sensor and check the condition of them.
Postby ChargedSolara » Fri Nov 12, 2004 1:42 am
replace your o2 sensor, i had that issue a month back, you can find the thread via search.
my code was P1135 but the explanation was also heater circuit open/short..not 100% sure if this is the same as p0135..
http://www.zer0.info/solaraguy/viewtopi ... ht=#120852
2008 C6 LS3
ChargedSolara
Postby JoeB » Fri Nov 12, 2004 7:17 am
If you have a Haynes repair manual, there is a procedure in there to check the sensor itself and the heater circuit for it. The heater circuit is very easy to check and also easy for the car's diagnostics. If it says there is a malfunction, unless there is a problem with the wiring, it is probably correct and the only fix is to replace the sensor. From what I read, it isn't NEAR as bad as the knock sensors. -JoeB
JoeB
Postby impactX » Tue Nov 16, 2004 11:38 am
I got that 0135 code, it was my O2 sensor in the rear bank.
impactX
P0135 & Traction control - HELP
Postby aptleo » Fri Feb 24, 2006 10:09 am
Hi,
I have a PO135 code problem, and naturally, replaced the O2 sensor. I bought the part online at theautopartsstore.com. The part I ordered was a Bosch 13355. But am not sure if they substituted it, cause the problem has not gone away.
After replacing the sensor, I reset the computer by disconnecting the battery terminal for a couple of minutes, and the check engine light disappeared for a few hours. But now its back on.
I checked with Haynes manual, mechanics at Midas & AutoZone to confirm that I replaced the correct sensor. And now the code is the same. Is there a way I can check if the new sensor if faulty?
Also, my Traction Control has gone off. This problem started soon after the sensor problem appeared, and after replacing it vanished for a few days.
The car suddenly freezes for a couple of seconds on sudden acceleration, and then the Trac Off light comes on. Before the replacment of the sensor, a mechanic who I checked with, told me both problems are related, though am not sure how.
After the replacement, the Trac Off light stayed off for a few days, even with 5K+ rpm revs of acceleration. ( I drive a lot, and made sure the light stayed off for more than 48 hrs after replacement before I resumed pushing the engine)
A little about the car: It's a 1999 SLE that I bought a few weeks back, and that engine check light's been ON since the second day I had it. The car has 135K miles on it, but is silk smooth. Couple of days back when I had a real good look under the hood, realized that a new engine (or completely re-worked one) has been put in, explaining the smooth ride. I thought it just was washed clean, when I bought it.
I don't have much experience tinkering with engines, though I know my way around them. So far I just had older cars, with not so much electronics.
Any help is welcome. Thanks in advance
Cheers,
Andy!!
1999 Solara SLE V6[/img]
aptleo
Re: P0135 & Traction control - HELP
Postby SleeperSolara » Fri Feb 24, 2006 11:14 am
aptleo wrote:Hi,
Cheers,
Andy!!
You goin' to get flamed man.
Postby Hsakuragi » Fri Feb 24, 2006 12:08 pm
^ because he's digging up from 04? well at least he did a search to find a 04 post.....
i'll say get a OEM sensor instead of Bosch
Hsakuragi
