SolaraGuy.com • View topic - Is this battery okay?
Postby ericatdallas » Thu Oct 17, 2002 8:17 pm
Something wrong with the top of the battery? Its slightly leaking acid. I know the terminals do it, but this is the first time I've seen it come from there.
It's not too bad, I've been monitoring it over a couple of weeks and the battery is still good. Just wondering if I should be concerned.
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
Postby Gunman » Thu Oct 17, 2002 8:21 pm
doesnt look bad in the pic, and lord know ive seen some really bad ones. as long as she's holding her charge you should be ok, in the long run, you may come to the point where it finally gives in
Gunman
Postby Blaze » Thu Oct 17, 2002 9:16 pm
looks fine to me, exactly like mine. but then again mine died a few days ago :o
Blaze
Postby Missay » Fri Oct 18, 2002 12:07 am
yea, my battery has some gunky stuff on it like battery acid yuckies, but the dealer said it was fine and normal..but dealers will say anything to get you to buy the car.
i brought a mechanic w/ me to check the car out first tho before i bought it and he said it was fine. so i think you're ok
Melissa
Missay
SolaraGuy Ambassador
Postby Chris » Fri Oct 18, 2002 9:56 am
I had a battery leak on my work truck and it corroded everything it leaked on just before dying.
I would recomend you replace it as soon as possible.
Chris
Postby Fairlite » Fri Oct 18, 2002 12:49 pm
Missay wrote:like battery acid yuckies
Im sorry that was just too cute, made me smile :D
Fairlite
Re: Is this battery okay?
Postby Flipside909 » Fri Oct 18, 2002 1:08 pm
ericatdallas wrote:Image
Your battery is fine. That's normal of aging batteries. Now if you are having starting problems, you may want to get your battery load tested at autozone or something.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Kenn157 » Fri Oct 18, 2002 3:20 pm
I put a DIE HARD "GOLD" in mine. $80+ :roll:
Had a 99 Solara SE V6. Had a 06 Tacoma. Now I have a 2008 Camry SE V6
Kenn157
Postby Missay » Fri Oct 18, 2002 3:51 pm
hahahah :angel: i couldn't think of what i could say to describe so i figured "battery acid yuckies" was the best verbal description i could think of. heheh...yuckies...it just sounds so...i don't know..yucky! lol
Melissa
Missay
Postby Cyanide41 » Fri Oct 18, 2002 9:42 pm
What I suggest doing is getting some baking soda and water mix it together and put it on there. That will neutralize the acid. Then get some terminal grease and put it on there to keep it from corroding further. Mine does that to, I wouldn't worry about it.
JAMES
SC3 Member
To find out how you can own this solara, send an e-mail slvrstreamsolara@aol.com
Cyanide41
JAMES
SC3 Member
Cyanide41
Postby ericatdallas » Sat Oct 19, 2002 9:07 am
terminal grease? I can still use Vaseline can't I? I wasn't sure only because normally it just leaks at the terminal. But since it runs fine I'll just monitor it for a while and clean it ever so often.
ericatdallas
Users browsing this forum: Google [Bot] and 15 guests
