SolaraGuy.com • View topic - Time For A Shave
Time For A Shave
Time For A Shave
Postby djsaltine » Fri Nov 12, 2004 5:00 pm
Well after long debate about de-badging my car or not, the answer suddenly came to me when I was washing her tonight. The SE on my driver side just came off. That settles it, time for a nice clean shave.
Any suggestions on "how to?"
J/K I already did my searching on the topic.
Maybe once I get computer savy, I'll even be able to post a pic.
I hope this was in the right forum. I don't know if it's really considered an "Aftermarket Upgrade."
http://fairtax.org
djsaltine
Postby toy4x4boy » Fri Nov 12, 2004 9:31 pm
OK so what is the point of this thread? :drinking:
toy4x4boy
Postby Jaimster » Fri Nov 12, 2004 9:53 pm
We do people refer to their Solaras like it's a person? And a female at that, so annoying! :-?
Jaimster
Postby djsaltine » Sat Nov 13, 2004 9:57 am
you do mean "prefer" not REFER, correct
refer makes me think of green things.
i wanted to join the 'pointless' thread count, I'm sure someone is keeping tabs.
oh well, guess i'll just curl up and die
http://fairtax.org
djsaltine
Postby FLASH » Sat Nov 13, 2004 10:10 am
No, he meant refer...he didnt say REEFER, he said refer...this thread is pointless thus far.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby djsaltine » Sat Nov 13, 2004 11:12 am
OK, my bad, I emphasized the wrong syllable when I read it. Sorry.
What would have been the correct way to post this so it wouldn't have been 'pointless'. Some quick pointers would help me out alot. Thanx
http://fairtax.org
djsaltine
Postby Duffman » Sat Nov 13, 2004 12:29 pm
...and out of nowhere, Duffman (Oh yeah!) dashes in and tries to steer the conversation back on course.
You're asking what the easiest way to de-badge your car is. Okay, we've got that part down.
I've never done it, so I don't know how they're fastened. You had the SE fall off, so you tell me - glued on, or is it actually connected to the car thru a hole? If it's glued on, get some fishing line (I'd wear gloves on your hands so you don't cut yourself up) and slice it behind the emblems. It should take them off, provided it's a strong enough test of line.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Re: Time For A Shave
Postby Paladin06Greg » Sat Nov 13, 2004 2:08 pm
8) It's very easy to do. Just get you some fishing line, double it, then work it back and forth behind the badge. It helps if you can warm the area up first with a hair dryer. You may need to do a little clean up with glue remover once the badge falls off. I've done all three of my cars this way..
Good luck
djsaltine wrote:Well after long debate about de-badging my car or not, the answer suddenly came to me when I was washing her tonight. The SE on my driver side just came off. That settles it, time for a nice clean shave.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby that1mexguy » Sat Nov 13, 2004 11:11 pm
i also recommend gloves (no one ever mentions that), but after sometime, if u dont heat it up, the dental floss, or fishing line starts getting to u. If u can use a hair dryer, but if u want, i got a heat gun u can borrow. Just hit me up, laterzzz
that1mexguy
Postby 2ksev6 » Sun Nov 14, 2004 12:23 am
The fishing line and hairdryer is good. For the rest of the junk (glue) that's left over use bug and tar remover to work it off. Worked great for the emblem I took off.
2ksev6
Shaving
Postby JMSinMaryland » Sun Nov 14, 2004 7:51 am
Check out my old Solara, (see link below) I wouldn't have had HER any other way. I used floss doubled up, I went through a lot of it but it worked fine. Finished up with some Goo Gone on a paper towel and that was all she wrote. Good luck. Jon.
http://mk23.image.pbase.com/u19/jmsinmd ... r_Jon5.jpg
JMSinMaryland
Postby Solaradude » Sun Nov 14, 2004 9:44 pm
i shaved everything but "SOLARA" since mines a 4 banger i didnt have SE v6 or SLE V6 on the sides. The toyota logos HAD to go
Solaradude
Shaving
Postby SolaraGuy22 » Sun Nov 14, 2004 10:17 pm
I shaved all of mine off and plan on using the "Solara" on the interior like this guy did. Image
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
