SolaraGuy.com • View topic - P1094
P1094
P1094
Postby Hsakuragi » Sun Nov 21, 2004 1:37 am
O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1)
can anyone sort of explain? thanks..
Hsakuragi
Postby Hsakuragi » Mon Nov 22, 2004 10:02 am
or ideas on how to fix this code? thanks...
Hsakuragi
O2 trouble code
Postby Jetfixer » Mon Nov 22, 2004 5:45 pm
Response time for the heated oxygen sensor’s voltage output
to change from rich to lean, or from lean to rich, is 1 sec. or
more during idling after the engine is warmed up
(2 trip detection logic)
This is from the service manual. You either have a failing oxygen sensor or a fuel trim problem. You should hope it's just a bad O2 sensor.
Jetfixer
Postby Hsakuragi » Mon Nov 22, 2004 7:41 pm
thanks, so bank 2 sensor 1 is the o2 sensor on the rear header right?
i think my fuel should be fine since i'm only 5.5 and safc ii tuned.... :(
Hsakuragi
