SolaraGuy.com • View topic - Brake Lights
Brake Lights
Brake Lights
Postby StockSolara » Thu Nov 25, 2004 9:24 am
For some reason my brake light keeps on coming on. My handbrake isn't up or anything. It just shows up sometimes than it goes away and comes back again. Any ideas guys?
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby s15lara » Thu Nov 25, 2004 11:06 am
this has been discussed many times before. try using the search button... but here is a hint. brakes are worn, or you might need brake fluid. check.
s15lara
Postby ZXLNT » Thu Nov 25, 2004 4:58 pm
Check the fluid level in the resevoir cup. It might be low. But look there first.
ZXLNT
Postby StockSolara » Thu Nov 25, 2004 5:08 pm
I already tried searching and my brake fluid is at max so iono. . .
2000 Lexus GS400
StockSolara
Postby sunrise_solara » Fri Nov 26, 2004 5:30 pm
My light was coming on too, early in the morning or late at night, especially if the car had been sitting for a while. Fluid looked good, but I added as much as I could, and now the light has gone off. Try that...and still inspect your front brake pads.
sunrise_solara
Re: Brake Lights
Postby cruze105 » Fri Dec 03, 2004 10:05 am
StockSolara wrote:For some reason my brake light keeps on coming on. My handbrake isn't up or anything. It just shows up sometimes than it goes away and comes back again. Any ideas guys?
i am having exactly the same problem as you right now, the brake light come on and off either when i make really sharp turn or when i break really hard or just comes up whne it feels like it lol.
does anyone know if the brake light that comes on relates to the the front and back brakes or just the back brakes?
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby xsolara33x » Fri Dec 03, 2004 11:46 am
most likely your front pads, but maybe both your front and rear pads... try checking your fluid level, if your fluid level is low it sometimes means that your pads are wearing down so its using more fluid or something like dat... had the same problem before...
xsolara33x
Postby StockSolara » Fri Dec 03, 2004 12:15 pm
actually the brake fluid went down barely a little bit so i filled it to da max and now it doesn't come on anymore thanks for all your help
2000 Lexus GS400
StockSolara
