SolaraGuy.com • View topic - Air in door *UPDATE*
Postby SleeperSolara » Mon Nov 29, 2004 9:15 am
Ok i found out why the air noises in my door was happenin'. :o
It was from a crack in the front-inside of the door, near the top of the door hinge and the the bottom of the door hinge.
In other words the seal/sealant is cracked top to bottom of the door. :(
The crack is on the inside of the door. :o
When you open the door and look towards the hinges and wire loom, the sealant on the inside of the door is what i'm talkin' about.
It's cracked top to bottom. :(
How should i get it fixed?? :( :(
