SolaraGuy.com • View topic - Camry Guages in Solara....
Postby Grant516 » Tue Nov 30, 2004 6:48 pm
The camry gauges have cool white needles, can we put those in our solara? the whole gauge cluster looks around the same size, and its the same engine?
Does this work?
Grant516
Postby MaxBoostSolara » Tue Nov 30, 2004 6:52 pm
that doesnt sound like too bad of an idea right now... they should fit since it is the same gauge cluster... can some1 confirm?
MaxBoostSolara
Postby CASTRO » Tue Nov 30, 2004 7:06 pm
its the same
CASTRO
Re: Camry Guages in Solara....
Postby shidosha01 » Tue Nov 30, 2004 8:09 pm
Grant516 wrote:The camry gauges have cool white needles, can we put those in our solara? the whole gauge cluster looks around the same size, and its the same engine?
Does this work?
It can be done but be sure that swapping needles may need recalibration. Let us know how it goes. Good Luck. 8)
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby junest » Wed Dec 01, 2004 12:40 am
Does this work?
What year camry are you talking about?
2004 Solara SLE V6 Convertible
Webpage
junest
super solara girl
super solara girl
Postby CASTRO » Wed Dec 01, 2004 12:53 am
its the gen4-4.5 camrys. its same as the solara, ive checked
CASTRO
Postby sunrise_solara » Wed Dec 01, 2004 7:41 am
If you want the needles, why don't you just swap that and save the hassle of dealing with a swap of the cluster (legal problems not logistics). Recalibration will be necessary though...
sunrise_solara
Postby Grant516 » Wed Dec 01, 2004 8:00 am
it'd be easier to swap the cluster
Grant516
Postby xsolara33x » Wed Dec 01, 2004 9:01 am
where would you have to go to recalibrate it??? the dealer??? how much will it cost, im thinking about the same idea... want some white needles instead of the red ones...
xsolara33x
Postby Jai_Jai_Binks » Wed Dec 01, 2004 10:10 am
just get em' reverse glows!
Postby impactX » Thu Dec 02, 2004 12:52 am
Here's what i did:
1) Take out the gauge from the car, make sure your fill up that fuel tank to full beforehand.
2) Pull the rpm and speedo needles upward a little and let it rotate to its natural position instead of being stopped by the stopper on the gauge.
3) Rotate the needle to COUNTERWISE by 180 degrees, let it rotate back ito its natural position, use 3m clear tape to mark its position (also use 3m tape to mark the the full fuel position). Do this a few times to assure an accurate marking spot. This step is only for the rpm needle and speedo needle
4) pull out all 4 needles, sand down the red color using sand paper.
5) paint the back of the needle with 1:18 model paint
6) put everything back together other than the fuel and temp needles, make sure the rpm and speedo needle rotate back to the same marking spot after you rotate them 180 degrees COUNTERCLOCKWISE. The natural position for the needles rotating clockwise and counterclockwise are DIFFERENT.
7) connect the gauge to the car and don't put on the transparent cover, drive the car around for 10 mins or so, put the temp needle back pointing little bit downward from center.
8) enjoy your new needles
impactX
Postby SolaraT » Sat Dec 04, 2004 6:45 pm
Nice DIY! Got pics?
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby impactX » Sun Dec 05, 2004 3:21 pm
impactX
Postby SolaraT » Sun Dec 05, 2004 3:38 pm
Very Nice!! Me Like!
2007 VW GTI
SolaraT
Postby that1mexguy » Sun Dec 05, 2004 7:09 pm
hmmm .. me like
that1mexguy
Users browsing this forum: Google [Bot] and 20 guests
