SolaraGuy.com • View topic - 12V power help
12V power help
12V power help
Postby Dawgz » Thu Dec 09, 2004 7:56 am
I kno this should be in some offtopic thing or somthing, or it shouldnt be,...i dono but like Im gonna buy a 7.2" tft screen from ebay, and i wanted to ask someone here with the gen 1\1.5 solara's for where is the best place in the car to draw the power from...and how? i need 12v for the screen, 8v for a camera im gonna use. Can someone help?
Postby Duffman » Thu Dec 09, 2004 8:03 am
As for the 12v? Draw from the battery like you would an amplifier.
But I've never heard of an 8v camera... only thing I could think of is some type of resistor.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby Dawgz » Thu Dec 09, 2004 8:18 am
yea i thought of the resistor too, its a small wireless camera, it has nightvision too so its coo...so i should just get 12v right from the batt? wat about a fuse? how do i put a fuse? do i even need one?
How do i put one in with the wireing? diagram anyone?
Postby Duffman » Thu Dec 09, 2004 8:53 am
Probably the same way you'd run an amplifier. In fact, I would get an amp wiring kit and go from there, so if you ever do get an amp you're already wired. Most amp kits have an inline fuse as well - the fuse should be as close to the battery as possible. I ran mine from the battery, around the air filter, to the back of the engine bay and behind that protective fire retardant stuff... then over to the passenger's side. There's a rubber plug there with a bunch of other wires going into it... CAREFULLY use a pocket knife to snip a small hole in this. Slip your wire through the hole and push, it will come out below your glovebox (take off that black plastic cosmetic cover under it so you can see where it's coming from). You can get a y-piece... thingey... that will branch the wire off into two terminals... put this under the glove box area. Since you'll need power regardless for the camera, run the other wire back to the trunk (pull the carpeting up).
If you think you'd put a sub in, let me know about how much power it'd run and I can give you an idea of what to run for wiring.
Duffman
Postby pythonjosh » Thu Dec 09, 2004 9:46 am
Dawgz wrote:yea i thought of the resistor too, its a small wireless camera, it has nightvision too so its coo...so i should just get 12v right from the batt? wat about a fuse? how do i put a fuse? do i even need one?
I've got an extra line coming straight from the battery that I wire all my acessories up to, including my CD player.
Schucks/Kragens/Checkers has inline fuse wires which is what I used. I don't know how you're gonna find 8 volts anywhere in the car. It has to be 8 volts DC? Why not 12?
pythonjosh
Postby Dawgz » Thu Dec 09, 2004 2:20 pm
because check the stats for the camera...
Wireless Camera specification
Image Pickup: 1/3 inch CMOS
Electronic Shutter: 1/50 - 1/10,000 second
Definition: 380 TV Lines
Scan Frequency: NTSC, 60 Hz
Min. Illumination: 0 LUX
Output Frequency: 900 MHz - 1200 MHz
Camera Power: DC +8 V
Transmission: 150-450 feet line of sight
Camera runs on 9-volt battery or AC adapter
Receiver Specifications:
Output: Video RCA Jack & Input to any VCR or Television
Voltage: 9-12V DC, power consumption: 1.2W
Receiver size: 2.5 in. x 5 in. x 0.5 in (60 mm x 125 mm x 12 mm)
Composite video connections on receiver
any help? and wat KIND of fuse do i buy? where?
Postby Dawgz » Fri Dec 10, 2004 1:26 am
anyone?
Postby mycrobyte » Fri Dec 10, 2004 11:19 am
http://www.powerstream.com/dc-dc.htm
Model Number PST-DC292 DC/DC Converter
Input Voltage Range 6 VDC to 30 VDC (see chart below)
Peak Output Power 24 Watts
Peak Output Current 2-3 Amps
Output Voltage Nominal 1.5, 3, 4.5, 5.0, 6.0, 9.0, 12.0 Volts
Output Voltage Typical See chart below
No-Load Overhead 10 to 40 mA depending on voltage setting
Line Regulation 1 to 2%
Load Regulation 2 to 5%
Efficiency 54 to 78%
Dimensions 100 x 70 x 32 mm
4 x 2.75 x 1.25 inches
Weight 200 g, 7 ounces
Your camera runs off a 9V so you can use this at the 9.0 v setting, it has plenty of amps to power it also.
Radio Hack proly has what you need also. Tell them you need a 12v to 9v DC:DC power supply.
:evilbat:
2000 V6 SE
mycrobyte
Postby Dawgz » Fri Dec 10, 2004 5:52 pm
thanx man, but i think all im gonna do now is just get a Inverter, and then place it in the back(trunk) and get a power strip that has like 8 outlets then plug in the camera, the reciever for the camera, and the dvd player lol..
