SolaraGuy.com • View topic - I got into some mishap today help
Postby Ryan » Sat Dec 11, 2004 2:55 pm
Okay I was driving my solara today and all of the sudden my steering wheels started to shake and then boom I heard a loud bang I came out and I see my front passenger wheel came off I have no idea what happened all the lug nuts were bent I quickly took them off. I have no idea what it is called but, you know the metal part where you put the hole on the wheels were bent well one of them I grab a hammer in my trunk and started hammering making it straight. I got it straight all right but the metal part became loose and it became dislocated to to the whole piece now I am running with 4 lugs instead of 5 :cry: Is it safe to run with the 4 lugs?? also how much do you think it will cost to fix that help
Ryan
Postby Ryan » Sat Dec 11, 2004 4:01 pm
yea just did some research I need a new wheel hub
bearing
Ryan
Postby Mole » Sat Dec 11, 2004 5:36 pm
its ok if you roll with 4 out of 5 lugs.
just play it safe and don't do anything too wild. its easy to replace a stud bolt.
Postby Turbosolara » Sat Dec 11, 2004 8:19 pm
Just broke one wheel stud today because the freaking cheap lug nut was striped. you are fine to drive with it, the replacement of the wheel stud range from $25 to $75. I just going to pay $70 for the replacement
Postby Ryan » Sat Dec 11, 2004 8:27 pm
guys it got worse the broken wheel stud went inside the rotors or the brake calipers now I am having a vety loud knocking sound coming from that front passenger wheel area can this day get anyworse :(
Ryan
Postby John7429 » Sat Dec 11, 2004 10:05 pm
Ryan wrote:guys it got worse the broken wheel stud went inside the rotors or the brake calipers now I am having a vety loud knocking sound coming from that front passenger wheel area can this day get anyworse :(
Don't jinx yourself by saying that.. :oops:
John7429
Postby Vi3tT3kNiqz » Sat Dec 11, 2004 10:38 pm
could this be the result of aftermarket rims fitment? i think if ur rims dont fit perfectly, this can happen. iono, someone correct me.
Vi3tT3kNiqz
Postby Ryan » Sun Dec 12, 2004 12:36 am
Vi3tT3kNiqz wrote:could this be the result of aftermarket rims fitment? i think if ur rims dont fit perfectly, this can happen. iono, someone correct me.
bro my Solara is bone stock now so I really don't think that's the problem
another question, the wheel stud is stuck inside somewhere in the passenger wheel area (rotors,brake calipers.etcc..) how safe is it to run this on 0.5 mile to the mechanic? Would something get damaged? because there is alot of clunking there
Ryan
Postby Ryan » Mon Dec 13, 2004 9:19 am
update got it fixed it wasn't really that hard to replace....but the plastic brake cover was all screwed up because of the wheel stud
Ryan
