SolaraGuy.com • View topic - Please Help with Glass Breakage Sensor
Postby super58177 » Tue Dec 14, 2004 1:38 pm
I have 99 solara and need help installing a glass breakage sensor control unit. Does anyone have any instructions? or Does anyone have any idea where the sensor should be located? Under the left or right dash? Thanks.
super58177
Postby Yanks0114 » Wed Dec 15, 2004 11:23 pm
Which alarm are you trying to install it for
Re: Please Help with Glass Breakage Sensor
Postby nummiesSLE » Fri Dec 17, 2004 2:37 pm
super58177 wrote:I have 99 solara and need help installing a glass breakage sensor control unit. Does anyone have any instructions? or Does anyone have any idea where the sensor should be located? Under the left or right dash? Thanks.
hey, I have a 2000 and the glass breaking sensor that was installed from the factory is located under the temp controls.... When i read the manual, it said they position it differently for toyota models, so i guess thats where it is most affective on solara's. lemme see if i can get you a picture
http://community.webshots.com/photo/232734639/232736511ZEhdbL
lemme know if that helps
edit.... thats where the monitor is installed , i beleive the GBS ecu is usually installed under the passanger side cowl
2000 Pearl White SLE V6 5speed
nummiesSLE
