SolaraGuy.com • View topic - Passenger side Rattle - [UPDATE - Issue Solved]
Postby {-_-} » Fri Dec 17, 2004 12:00 am
The annoying sound seems to be coming from the dash and starts at around 40-4mph. I searched and found similar problems from last year:
http://www.zer0.info/solaraguy/viewtopi ... sc&start=0
I checked the glovebox and the seat as others suggested but the problem seems to the elsewhere. I thought it was the outside mirror but I was wrong. Any other possible solutions?
Thanks
------ MY SOLUTION ----
Took apart the door panel following instructions I found by searching the forum. (Thanks)
For some unknown reason one of the 2 nuts (10 mm) was missing from a stud which held the track for the glass.. The rattle came from the stud bouncing agains the metal.
95 LE Coupe
99K
{-_-}
Postby Mole » Fri Dec 17, 2004 12:27 am
what should we call you by?
as for the rattle, take out your glove box and see if it still rattles when you drive.
Postby TadS » Fri Dec 17, 2004 7:40 am
Check the passenger seat. Mine rattled like crazy for a while; you can check this by pushing down on the seat when it starts rattling. Also it could be your front mud flap and the associated body trim under the car. Check and make sure those are all tightened up.
TadS
Postby Jai_Jai_Binks » Fri Dec 17, 2004 9:14 am
I know 5sfe's got a little viberation, but for a 1mz that a new thing to me. For my car, i just place the passanger seat as far back as possible and have it really reclined as much as possible and keep my laptop bag on it..it diminishes the rattles
seat rattle
Postby satchmo » Fri Dec 17, 2004 11:50 am
Is there anything that can be done about that pesky seat rattle? Mine gets worse in the winter and it is driving me nutz!
2000 Gold Dust Metallic SLE V6
TRD RSB
S/C'd a month ago
satchmo
Postby TadS » Fri Dec 17, 2004 10:22 pm
I stuffed a lot of foam rubber chunks into the springs under the seat. That seemed to help a bit.
TadS
Postby DatSRBoi » Sun Dec 19, 2004 8:39 am
OHHH SNAP...Weight reduction style, strip out the seats haha :evilbat:
Postby krook » Mon Dec 20, 2004 8:42 pm
do you have an aftermarket exhaust??
i have a JIC bullet exhaust and it's sooo loud that it vibrates my. . . .
here's the answer: balls.
oh, and also the emergency brake handle. if i hold it, it stops the noise.
krook
