SolaraGuy.com • View topic - aftermarket key
aftermarket key
aftermarket key
Postby Dawgz » Fri Jan 21, 2005 8:42 pm
if i were to get a remote start, i would need another key cause they need the original transponder key, so would this key work for my solara?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33717
i have a v6 se. (2000)
Postby jazzlara » Fri Jan 21, 2005 9:07 pm
i would suppose so. as long as you get it cut correctly.
jazzlara
Re: aftermarket key
Postby Jon11582 » Fri Jan 21, 2005 9:20 pm
Dawgz wrote:if i were to get a remote start, i would need another key cause they need the original transponder key, so would this key work for my solara?
I think any key will work after you put in Remote Start. Once the transpondered key is set for the remote start, the transponder should always be active and u wont need a second transponder to start the key anymore. Basically your engine immobolizer will become useless since the transponder is always in range of your ignition due to the key being inside.
At least thats how I think itll work.
2000 Black Solara SE
Jon11582
Re: aftermarket key
Postby Yanks0114 » Fri Jan 21, 2005 9:51 pm
I'm pretty sure thats not true.
I'll check it out tomorrow
Re: aftermarket key
Postby Jon11582 » Fri Jan 21, 2005 11:50 pm
Let me know. Im curious too. I figure since the key is sacrificed to be placed by the ignition so that itll work without a transponder present, then its gotta sit next to the ignition permenantly. I dont have engine immobolizer so I didnt have to deal with it.
Jon11582
Postby Parke10 » Sat Jan 22, 2005 12:37 am
if it only has to be around it id Tape(yeah ghetto) it behind the dash next to the ign
Parke10
