SolaraGuy.com • View topic - Exhaust piping size
Exhaust piping size
Exhaust piping size
Postby SeanJohn0716 » Mon Feb 07, 2005 3:31 pm
Question 1:
I searched and saw a mix of 2", and 2.25" piping on the stock exhaust system. Can anyone confirm the size?
Question 2:
I am starting to look more seriously into turboing my car. What size piping do you turboed 2.2L guys have?
SeanJohn0716
Postby Jon11582 » Mon Feb 07, 2005 4:31 pm
I think theres only one turbo'ed 2.2L, and hes selling his car.
I think its 2" stock. I'll be ripping my stock catback off this weekend, weather permitting, so if you dont find out by then, I'll find out for you.
2000 Black Solara SE
Jon11582
Postby thealkimo » Mon Feb 07, 2005 4:41 pm
stock is 2.25" for both i4 and v6
thealkimo
Postby swimshady906 » Tue Feb 08, 2005 1:51 am
Thats sad that its the same size for both...
02' S2000 Silverstone
swimshady906
Postby swimshady906 » Tue Feb 08, 2005 6:05 pm
I got dual 2.25's ... im following in gregs footsteps i guess... .
swimshady906
Postby SeanJohn0716 » Wed Feb 09, 2005 10:25 am
Ok, would it even be worth getting anything more than that? I mean, like I said i want to turbo the car eventually, but would I even need to go bigger than 2.25" or 2.5"?
And as far as N/A basic mods go, would there be any gains from just getting an axle-back exhaust?
SeanJohn0716
Postby StockSolara » Wed Feb 09, 2005 12:56 pm
if ur gonna go turbo u should get a 3 inch pipe atleast
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby SeanJohn0716 » Wed Feb 09, 2005 2:15 pm
SeanJohn0716 wrote:And as far as N/A basic mods go, would there be any gains from just getting an axle-back exhaust?
For example:
Intake, Header, 50 dry shot N02, UDP, Axle-Back exhaust
Would an axle-back exhaust yield any gains AT ALL on this setup?
SeanJohn0716
Postby swimshady906 » Wed Feb 09, 2005 2:26 pm
SeanJohn0716 wrote:Ok, would it even be worth getting anything more than that? I mean, like I said i want to turbo the car eventually, but would I even need to go bigger than 2.25" or 2.5"?
Turbo the car first, then work out the exhaust .
swimshady906
Postby SeanJohn0716 » Thu Feb 10, 2005 6:45 am
Would 2.75" exhaust work for turbo 2.2? or does it have to be 3"+? I mean, I understand on the V6, since the exhaust is catered towards the V6 engine on our cars, but since the I4 is smaller and lower output to begin with, would it make sense to go 3" on a V6 and around 2.75" on an I4.
SeanJohn0716
Postby Jon11582 » Thu Feb 10, 2005 7:54 am
I'd get 3" if I was boosted, 2.2L or otherwise. If your spending that much on a turbo set up, then a 3" Custom exhaust piping shouldnt impact your wallet too much more. Why would you only want an Axleback if your going to boost it? I would go Catback all the way...at least.
Any size piping would work, the key is finding what works optimally.
Axle back on N/A I4 might give very nominal gains...maybe 2-3 HP if even.
Catback, maybe 5-10 HP
Jon11582
Postby SeanJohn0716 » Thu Feb 10, 2005 12:13 pm
Reason I ask about Axle-Back is because I am planning on an STS Turbo style setup
http://popularhotrodding.com/tech/0411phr_sts/
SeanJohn0716
Exhaust piping size
Postby noodlerooney » Tue Feb 15, 2005 10:54 am
Took my muffler off, putting straight pipe on, looks like 2" at the muffler flange. Don't know if it's the same at other locations.
15,001 miles, Garage Queen
noodlerooney
Postby Turbosolara » Tue Feb 15, 2005 11:25 am
stock pipe is 2". I had 2.5" and i think i should have go for 3". Because in reality that NO shop can bent your pipe as good as mendral bent. If the bent reduce the pipe size to 2", then your exhaust is only effective as 2".
So i get 3" pipe, i would hope that I can get at least 2.5 or 2.75 diamter at bent area. I found in front of cat-convertor has a section is so tinnny i think it is less than 2". I gonna get rid of them soon
