SolaraGuy.com • View topic - Stock radio question
Postby guest » Thu Nov 07, 2002 10:28 pm
My 99 solara has no radio but we got a hold of a stock one(00 camry I think which is pretty much the same size) however, it did not come with the stock amp. I was wondering if its possible to use the stock radio w/o a stock amp or if it will work fine with a aftermarket amp?
guest
Postby Gunman » Thu Nov 07, 2002 10:35 pm
ok, the radio will fit, but i cant remember if the mounting brackets are the same from the camry to the solara, i think so but either way worst case is 20 bucks for a new set,
Now on this radio, on the back is there two slots for plugs or is there one. two is a non amplified radio, one is for an oem amp. if you have two, doesnt matter what was in there before, it will work.
Gunman
Postby Guest » Thu Nov 07, 2002 11:43 pm
two plugs :) thanks. ill check the mounts tomorrow.
Guest
Postby Guest » Thu Nov 07, 2002 11:45 pm
oh btw if it was one plug, that meant the one plug would of gone into the stock amp and more wires would come out of the stock amp to connect to the rest of the car right?
Guest
Postby Gunman » Fri Nov 08, 2002 12:03 am
yep
Gunman
stock radio
Postby Solara916 » Thu Dec 19, 2002 2:43 pm
they sell solara's without a stereo?
Solara916
Re: stock radio
Postby Yanks0114 » Thu Dec 19, 2002 6:33 pm
SactoSolara wrote:they sell solara's without a stereo?
No, someone probally put an aftermarket headunit in their solara and then sold the car, but kept the stereo. Or the stock headunit could have been stolen
stock stereo
Postby Solara916 » Fri Dec 20, 2002 2:51 pm
i thought it sounded funny.
i thought that was the reason, but i had to ask. :D
Solara916
