SolaraGuy.com • View topic - help with lighting
help with lighting
help with lighting
Postby 209solara » Tue Feb 08, 2005 8:48 pm
im trying to hook up the light from my boost gauge and i dont know where to wire the power or ground to. i want the light to only be on when my head lights are on. any help?
209solara
Postby bassthrive » Tue Feb 08, 2005 9:21 pm
Hook it into the gauge cluster power wire (green/silver wire if memory serves). This will require pulling out your cluster of course. Also, behind the cluster you will see a bolt that is perfect for grounding.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby 209solara » Tue Feb 08, 2005 9:26 pm
first off are you sure its the green one, second which of the 3 gauge cluster wire clips should i use.
209solara
Postby bassthrive » Tue Feb 08, 2005 9:34 pm
Again, going from memory I believe it is the brown plug. Could someone confirm this? When in doubt, use a test light to see which wire gets the juice when you flip on the headlights.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby noodlerooney » Thu Feb 10, 2005 9:25 am
Yes, it's the brown connector, and if you ground the new gauge to the black ground wire next to the green/silver power wire, you can dim the guage along with the dash lights. I like to use the vampire wire taps with the built-in female spade connector to tap into wires, don't like to cut wires, neater install.
15,001 miles, Garage Queen
noodlerooney
Postby 209solara » Thu Feb 10, 2005 11:07 am
thanks for the help guys
209solara
