SolaraGuy.com • View topic - Can someone tell me what code P1705 means?
Postby Sn88pyBQ » Wed Feb 16, 2005 8:09 pm
CEL came on today, took it to get it checked and the guy got code P1705 but he can't find what the code means on his computer. Can anyone help me? Thanks
Sn88pyBQ
Postby Jackass-Jeff » Wed Feb 16, 2005 11:59 pm
i'll post what it means after I get to work tomorrow morning
1GR-FE ftw!
Jackass-Jeff
Postby Jackass-Jeff » Thu Feb 17, 2005 4:33 pm
NC2 Revolution Sensor Circuit Malfunction
This sensor detects the rotation speed of the clutch drum
3 possibilities:
Open circuit in direct clutch speed sensor circuit
Direct clutch speed sensor itself
wiring problem to the ECU.
The code will show if it detects a malfunction for over 4 seconds
1GR-FE ftw!
Jackass-Jeff
Postby Sn88pyBQ » Thu Feb 17, 2005 8:34 pm
What does that mean? Is is safe to drive like this?
Sn88pyBQ
Postby Jackass-Jeff » Thu Feb 17, 2005 8:37 pm
transmission miss-shifting seems to be the only thing that may happen (i think)
if you're still under powertrain, go to the dealer =P Otherwise, call a dealer and ask to speak to a service advisor and ask his advise and get a rough estimate... ask if it's a safety issue!
1GR-FE ftw!
Jackass-Jeff
Postby Sn88pyBQ » Thu Feb 17, 2005 8:55 pm
Wow, seems like this could cost alot to fix. Will it damage the car even more if i drive it like this is what I want to know. If it will, I'll have to get it fixed ASAP. Thanks
Sn88pyBQ
Postby Jackass-Jeff » Thu Feb 17, 2005 9:41 pm
call and ask... i've never seen that code get pulled before =x
1GR-FE ftw!
Jackass-Jeff
Users browsing this forum: Google [Bot] and 28 guests
