SolaraGuy.com • View topic - Which engine year is better?
Postby Jeremy1210 » Sat Feb 19, 2005 12:15 pm
Hey all,
I'm looking to swap the V6 1mzfe into my 6th gen celica. I have been looking at the different years of the 1mzfe adn I cannot seem to decide on what year to use. So I figured that you all who drive hte fast motor can help me out.
Im looking for the enigne with the most stock HP/ ft lb that is the easiest to mod( S/C) and do internals. A guy was telling me the 97 1 mzfe, but I have looked at some profiles and noticed that 99 seems to be a popular year. I don' think there were any differences b/w those years.
Looking for information and opinions of the V6
Thanks
Jeremy
Jeremy1210
Postby Jon11582 » Sat Feb 19, 2005 1:47 pm
Best I think is the one out the late ES300. That put out 210 and had VVTi. I don't believe they evermade a S/C for that one though.
The solara/camry is pretty much the base 1MZ.
The Sienna one, I think had dual throttle bodies. And theres the new 3.3L 3MZ in the ES330 that puts out 230HP, but Its probably bigger and an even tougher fit into the celica.
2000 Black Solara SE
Jon11582
Postby Jeremy1210 » Sat Feb 19, 2005 2:16 pm
I did see the es300 b/c it had more power, but no S/c for it, like you said, but would it be possible to put the s/c on it? Since they are the same basic engine code
Jeremy1210
Postby Jackass-Jeff » Sat Feb 19, 2005 3:14 pm
NO!
The VVT-i in ES will not work with the supercharger. The active control of the valves will prevent any good gains. Pre VVT-i ES 1MZs will work w/ the s/c.
If you do not want to super charge the car, go with a 3MZ FE. It is NOT bigger than the 1MZ. It's simply a 1MZ bored out to a 3.3L displacement (as opposed to 3.0)
VVT-i works off oil pressure levels and will not give substantial gains when supercharged unless the ECU is prepped for it.
You may want to research a 3S-GTE instead of a 1MZ... it's easier to transplant (from MR2 to Celica) and will hold better gains =P plus the torque on those... wow...
1GR-FE ftw!
Jackass-Jeff
Postby swimshady906 » Sat Feb 19, 2005 6:21 pm
Im all for the 1mz but Jeff makes a good point. The 3sgte has been known to pump out over 500 horses stock internals. The 1mz is a costly project.
02' S2000 Silverstone
swimshady906
Postby Turbosolara » Sat Feb 19, 2005 10:34 pm
i agree 3SGTE would be a more practical project. 1mzfe has really limited aftermarket support. If you decide go for ES300 motor, you have to beware that they dont have manual transmission aviliable. i think there are no difference between any year of 1mzfe out of toyota, but i think 49 states motor has a bit more power then california edition? someone please confirm this idea
Postby Jon11582 » Sun Feb 20, 2005 8:50 am
UltraslowSolara wrote:i agree 3SGTE would be a more practical project. 1mzfe has really limited aftermarket support. If you decide go for ES300 motor, you have to beware that they dont have manual transmission aviliable. i think there are no difference between any year of 1mzfe out of toyota, but i think 49 states motor has a bit more power then california edition? someone please confirm this idea
For Camry/Solara 1MZ, 200HP for the 49 states, 198HP to meet Cali emissions.
Jon11582
Postby Jeremy1210 » Sun Feb 20, 2005 11:14 am
I agree that the 3sgte has more aftermarket support, but everyone with a celica is doing that now. I was to do something different. Trust me that I have looked into doing that swapfirst, but since I know the 1mzfe has been put into a 90 celica and a MR2, I know it can be put in mine. It will be about the same difficulty and expense as a 3s swap. The 3s is not more practical since it doesn't just drop in b/c of the current eninge in my celica. Either was I would have to redo the motor mounts.
When did the VVTI start with the 1mz? Then I will have to go with the non- VVTI if there is room for the S/c in the enigne bay, if not then the 3mzfe or the vvti 1mzfe. I have to take measurements of the engine bays from the 90 and my 94 to see how much a difference there is to know how much room i have to play with for the SC.
Does anyone have the dimensions on the S/C?
Jeremy1210
Postby Jackass-Jeff » Sun Feb 20, 2005 12:04 pm
If you REALLY want to try something different...
2AZ-FE swap (From 02+ Solara/Camry 4-cyl and tC) and turbo that mofo! =D
VVT-i can be disabled by the ECU (using the Toyota "Brick" scan tool - I can have it done for you if you're in So. Cal... or just have the ECU in So Cal at any point in time)
1GR-FE ftw!
Jackass-Jeff
Postby Jeremy1210 » Sun Feb 20, 2005 5:00 pm
Im not a huge fan on the 2azfe. Its good, but with the S/c its only at 200hp. I know a turbo will be better, but if I was going to do that, then I'd do the 3sgte swap.
Jeremy1210
Postby Mandarinsolara » Sun Feb 20, 2005 5:19 pm
the 1mz-fe in a celica would throw off the balance in handling. thats why the tiburon V6 never did so hot in the sport compact comparos. but as far as straight line performance, i would love to have one with a 1mz.
Mandarinsolara
Postby Jeremy1210 » Sun Feb 20, 2005 6:09 pm
How would it throw off the balance? From what I have read the 1mzfe weighs the same as the 3sgte. so, if you are talking from a weight standpoint, you are incorrect.
Jeremy1210
Postby Turbosolara » Mon Feb 21, 2005 12:46 am
swap a SR20DET.....the buttom end is good for 400hp! drive a automatic vvti 1mzfe doesnt get you become hotter.....
Postby Jai_Jai_Binks » Mon Feb 21, 2005 8:48 am
Your easiest thing would to to talk to adrian (SBcelica) on celicatech.com; he did a 1mzfe swap to his 5th gen celica. Last i read, he had figured out debudding the codes for the swap and was on his way to getting his swap certified. By all means, its no easy feast....there will be a lot of custom work entained in such. He did it cus' not a lot of celica dudes do this swap. Chat on the mr2 boards, and there you will see other few 1mzfe mr2's.
Its nice that you would want to use a 1mzfe on your 6th gen...no offence, but if i were you i'd buy a 5th gen front clip and swap out a 3s motor into your 5sfe, but thats just ME!
Edit: Also to answer your questions, 1997-2002 camry's imzfe engines are all the same, they are all non vvti (watch out for some american edition 2002 camrys that apparently did have vvti). For solara, any 1999-2002 solara would be compatible). If you do go ahead with this feat, do talk to eddie to see if you want to acquire a s/c as well, a while back he had some sienna s/c for sale at an unbelivable price...the camry/sienna differences in additional parts was close to $250...and GOOD LUCK!
Postby Jackass-Jeff » Mon Feb 21, 2005 6:46 pm
VVT-i (1MZ) was seen in the 03+ Camry (at least the SE...) I'm not sure if any 1MZ (02 Camry) came with VVT-i...but I think 98+ 1MZ (or 99?) in the ES 300 had VVT-i.
Perhaps you should go to a Solara meet (assuming any local to you are supercharged) and check out the size of the block and SC.
1GR-FE ftw!
Jackass-Jeff
Users browsing this forum: Google [Bot] and 28 guests
