SolaraGuy.com • View topic - Manual transmission fluid
Postby Midias » Wed Feb 23, 2005 7:29 am
Hey guys I did a search but did not find much. I was wondering what you recoment for manual transimmion fluid I heard redline is good, but I wanted to see what else is out there. Also does the dealer have a specific kind I remeber on my accord they recomended honda brand MTF.
Postby lazyboyz69 » Wed Feb 23, 2005 11:24 pm
i didn't find much either.... i wanted to know how to change MTF or flush it. Where is the drain bolt? on the trans?and pictures would be helpful...and where to put the fluid back in....
lazyboyz69
Postby Fletch » Thu Feb 24, 2005 4:05 am
Any full synthentic 75W 90 gear oil. OE stuff is very good but who knows if the dealership sells the same stuff the plant put in. My trans fluid still looked new when I had it changed at 115k with the clutch. I went to a small local oil company and bought whatever brand they carried. Took almost 5 quarts.
2006 Legacy GT spec.B
Fletch
Postby supamouse09 » Thu Feb 24, 2005 11:11 am
in my car i used torco oil only.
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Users browsing this forum: Google [Bot] and 29 guests
