SolaraGuy.com • View topic - My car starts but ..
Postby that1mexguy » Sat Mar 05, 2005 7:41 am
.. it's taking it about 2-3 seconds longer!! Waz up with that?? Lately I've noticed that I have to crank it for about 2-3 seconds longer (maybe 5) for it to start, and once it starts everything is cool ... do you guys think I should be concerned? I just hope this is not an early symptom for something else. Thanks in advance for your replies.
:drinking:
that1mexguy
Postby wiz2 » Sat Mar 05, 2005 7:51 am
Sounds like the battery. Go to Autozone/Advanced Auto to get it checked for free.
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby that1mexguy » Sat Mar 05, 2005 8:27 am
battery was just replaced less than 6 months ago, think it may be defective?
that1mexguy
Postby djsaltine » Sat Mar 05, 2005 9:14 am
wiz2 wrote:Sounds like the battery. Go to Autozone/Advanced Auto to get it checked for free.
^^agreed
any recent "under the hood" work??
plugs/wires?
http://fairtax.org
djsaltine
Postby that1mexguy » Sat Mar 05, 2005 9:26 am
^^agreed
plugs/wires?
nope... dang... what else could it be?? :(
that1mexguy
Re: My car starts but ..
Postby Paladin06Greg » Sat Mar 05, 2005 9:45 am
What does your air filter look like? When was the last time you had a tune up? Is your throttle body dirty? If you're in the cold, wet, rainy, snowy northeast, you might want to think about putting some water removal additive in your gas tank. Hey if it's turning over it's getting fire, maybe weak fire but fire.
Good Luck!
that1mexguy wrote:.. it's taking it about 2-3 seconds longer!! Waz up with that?? Lately I've noticed that I have to crank it for about 2-3 seconds longer (maybe 5) for it to start, and once it starts everything is cool ... do you guys think I should be concerned? I just hope this is not an early symptom for something else. Thanks in advance for your replies.
:drinking:
Paladin06Greg
Torqued Solara
Torqued Solara
Postby FLASH » Sat Mar 05, 2005 10:07 am
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby that1mexguy » Sat Mar 05, 2005 10:36 am
I read ur thread, but my car does start ... just kinda slow so I'm not sure it could be the same, unless your car would take a while prior to when it finally died on u, did u experience something like that?
Paladin06Greg wrote:What does your air filter look like? When was the last time you had a tune up? Is your throttle body dirty? If you're in the cold, wet, rainy, snowy northeast, you might want to think about putting some water removal additive in your gas tank. Hey if it's turning over it's getting fire, maybe weak fire but fire.
Good Luck!
It's been a while since i cleaned my air filter (i have the CAI, it's kinda hard to reach it, hehe) but i will check into all your recommendations, thanks a lot guys!
that1mexguy
Postby Midias » Sat Mar 05, 2005 12:51 pm
mine sometimes does it in the morning but after it is normal. Altho mornings around here have been about 20F
